Old 08-13-2013, 08:22 PM   #1
Supercharged SS
Drives: 2010 Camaro
Here's the damage and the plan to rebuild
Since I jacked my other read thread up with a bunch of yahoo's I'll just make a new one. Chances are this will be jacked up again but what else is new!!
They got the motor pulled and torn apart this am. It does look like then when the car hit the limiter hard, the tb closed and forced the nitrous to pack up in the intake tube. When the tb opened back up all the nitrous ran in and was dumped in the first two cylinders it found.
It melted the one piston and started to crack the second. Some of the metal jumped over to the other side of the engine and marred up a piston over there. It also melted some metal into the cylinder wall where the piston was burnt up the worst. After cleaning the metal we found the it did leave an indentation in the sleve. The rest of the engine looked fantastic and still new.
Now what to do. It makes no sense to resleeve this block. That combined with all the machining needed to get it ready just makes financial sense to me. Ted opted to go with an ERL superdeck, stock cubes. The only setback may be the lead time on the block. TBD. The rods I have, Eagle (http://texas-speed.com/p-441-eagle-h...000-bolts.aspx), still look brand new. Not even any bluing. If they, along with the stock crank, check out, they will get reused. We'll need new pistions and that's about it.
The stock heads are fine but will more than likely be milled to bump the compression. The current calculated compression is 9:7.1. I guess Ted is going to dig up the whistle test(?) to get the exact number. So that will get bumped along with changing fuel from 104 to C16 which makes my life easier since the GN is also on C16.
Just add in an LPE nitrous controller and that's about it. It'll be back to the track and see what it'll do.
Old 08-13-2013, 08:36 PM   #2
Supercharged SS
Drives: 2010 Camaro
Sorry. I meant for this to be in the V8 Forced Induction section. I must still be traumatized from blowing this thing up!
Old 08-13-2013, 08:42 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
What yahoos? Lol
Sounds like a plan, I'm heading this route fortunately my block is ok! Bent exhaust valve misfortune for me bud. I'm going boost! Fak this NA stuff lol.
Keep me posted on your build bud.
Old 08-13-2013, 08:45 PM   #4
Supercharged SS
Drives: 2010 Camaro
Originally Posted by litle88 View Post
What yahoos? Lol
Good luck. I'll try and keep this thread updated with the progress.
Old 08-13-2013, 08:50 PM   #5
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2018 Silverado
Yahoooo!!! Thread moved so I can be useful here.
Old 08-13-2013, 08:53 PM   #6
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
That sucks. Good luck with your rebuild and hope it all comes out the way you want it.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 08-13-2013, 08:53 PM   #7
Supercharged SS
Drives: 2010 Camaro
Thanks!! When I get some time I'll fill you in about everything in that pm.
Old 08-13-2013, 09:13 PM   #8
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
ERL block with Callie's rods and crank along with Diamond Pistons.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 08-13-2013, 09:15 PM   #9
ToddB
Drives: 2011 2SS Convertible Supercharged
Good luck with your car. It was nice meeting you and seeing your car on our vacation in july.
2011 Camaro SS, LS3,Whipple SC, 13 PSI,CAI intake, ARH 2" Headers, Corsa exhaust, ZL1 fuel pump with ADM FPCM LS9 Cam and Meth,ID850, BMR suspension upgrades,Tune by JRE
ToddB is offline   Reply With Quote
Old 08-13-2013, 09:15 PM   #10
Supercharged SS
Drives: 2010 Camaro
Originally Posted by Detoxx03 View Post
ERL block with Callie's rods and alont with Diamond Pistons.
Thanks! I will sent this info to Ted. It's out of my hands now. I'm just doing PR and finance.
I'm assuming coated pistons.
Old 08-13-2013, 09:20 PM   #11
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
So...your TPIS TB closed and caused this? Did I read that correctly?
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 08-13-2013, 09:21 PM   #12
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
Good luck with the rebuild
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 08-13-2013, 09:28 PM   #13
Supercharged SS
Drives: 2010 Camaro
It closed because the car broke the tires loose bad at 100' and it revved to almost 7400. It hit the limiter hard and the car shut the tb to protect itself. The car needs to protect it self from the driver more often!
Nothing to do with the TPIS. It's been money all along.
Old 08-13-2013, 09:30 PM   #14
Turbo99
Turbo99's Avatar
LOL, I got it! I was waiting for the slamming shut TB saga to open up on TPIS. Good to hear you have no clue how to lift...lol
