Flowmaster Exhaust
Old 08-19-2013, 06:51 PM   #127
jrpxxii
jrpxxii's Avatar
Originally Posted by Chris82xx View Post
Hopefully you get the right spark plugs......j/k
I don't feel like reading through all the pages, but what are you doing as far as the motor?
Forged and stock cubes. Hes scared to go fast and build anything bigger
Old 08-19-2013, 06:56 PM   #128
Supercharged SS
Drives: 2010 Camaro
You're on the same boat as me speedy. Ill see you at the blown engines Thursday night support group. Come early, it's your turn to make coffee!
Old 08-19-2013, 07:00 PM   #129
Supercharged SS
Drives: 2010 Camaro
I bought some NGK123GOF#^KYOURSELF'S. Supposed to be awesome for 9 second camaros.
Old 08-19-2013, 07:08 PM   #130
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Hahaha. Those are the same plugs i run.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 08-19-2013, 07:11 PM   #131
Supercharged SS
Drives: 2010 Camaro
Awesome. Welcome to the club. Make sure you bring a garbage can to the track. It makes for a quicker cleanup when the shit hits the fan.
Old 08-19-2013, 07:13 PM   #132
jrpxxii
jrpxxii's Avatar
You like cream and sugar?
Old 08-19-2013, 07:15 PM   #133
Supercharged SS
Drives: 2010 Camaro
And a shooter of C16. Helps me forget about what happened.
Old 08-19-2013, 07:25 PM   #134
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
He's living a dream. Just a dream.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 08-19-2013, 07:51 PM   #135
thahemp
Geek
thahemp's Avatar
Maybe i should market a diaper for all these track cars.
x = ~x
Old 08-19-2013, 08:23 PM   #136
Supercharged SS
Drives: 2010 Camaro
Teds already got us on diapers....
It's a 9 second requirement.
Old 08-19-2013, 08:31 PM   #137
Rdunn
Really, Really Fast
Rdunn's Avatar
lots of questioning going on in here on a set-up that on stock cubes & with a twin screw is out running built big cube motors with high hp numbers.
you would think instead of getting opinions on changes, he should be answering questions.
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 08-19-2013, 08:33 PM   #138
thahemp
Geek
thahemp's Avatar
There are lots of people around here that know what's up.
x = ~x
Old 08-19-2013, 08:41 PM   #139
Supercharged SS
Drives: 2010 Camaro
Ha, well, we all have our own thoughts. I've watched everyone since the fall of 2009. I've seen what works and what doesn't. What works for me doesn't work for everyone else. Their missing denominator is having Ted every step of the way. Plus, we never started out with a goal. Things just evolved. We made progress, hit a wall, broke though, made some more progress, another wall, etc. this is another wall. We have new solutions being implemented and plan on breaking through this wall.
I've never told Ted I want xxx rwhp or want to go x.xxx at the track. He has his part and I have mine. If I don't log and give him feedback he can make any adjustments. It is work. It's not as easy as it seems. No one see's all the testing that goes on behind the scenes.
I'm sure you noticed that in open to listening to everyone's thoughts but never changed my plan. Small cubes, small blower, some nitrous, and having it dialed in like a mofo.
Old 08-19-2013, 08:46 PM   #140
Supercharged SS
Drives: 2010 Camaro
I can't find the breakdown buts its simple:
New GM LS3 block
Stock crank
Upgraded main/head studs
Callie's Ultra LS rods
Weisco forged/coated 10:0.1 pistons
New pushrods and springs
Stock L99 heads (my originals)
Same JRE smooth idle cam
New valves (no idea which ones)
Spark plugs (no comment )
I think we're switching to c16 fuel
Still 125 shot on wot
New Super Car coilovers with custom pockets by Farks
And Farks help with the setup.
I think that's about it.
