Solo Performance
Old 08-14-2013, 12:38 PM   #43
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Looks like zr1 plugs from the pic.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 08-14-2013, 12:40 PM   #44
Supercharged SS
Drives: 2010 Camaro
Maybe.... Teds uses what Ted uses.
Sparks plugs are like assholes...you know how the rest of that goes. Im not going to start another spark plug debate!
Old 08-14-2013, 12:49 PM   #45
unforgiven
Drives: 2011 ss
Originally Posted by SRT10KLLR View Post
Forget C16 guys use the new Shell URT Advanced unleaded gas.
It is just as good as C16 if not better and because it is unleaded will not kill your 02 sensors or cats.
vp c-16 = 117 motor octane
shell urt advanced= 105 motor octane
not even close in octane!
unforgiven is offline   Reply With Quote
Old 08-14-2013, 02:32 PM   #46
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
Originally Posted by Supercharged SS View Post
Going with a new GM 376.
LS3 or LSA?
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 08-14-2013, 02:34 PM   #47
Supercharged SS
Drives: 2010 Camaro
Originally Posted by TinyToasta View Post
LS3 or LSA?
LS3
Old 08-14-2013, 03:56 PM   #48
djw32
Drives: on blocks
How high do you spin the motor? How much psi is it making?
djw32 is offline   Reply With Quote
Old 08-14-2013, 04:00 PM   #49
Supercharged SS
Drives: 2010 Camaro
Shifts around 7k.
15.5-16 psi
Old 08-14-2013, 04:50 PM   #50
djw32
Drives: on blocks
That's impressive. How high did the IAT get?
Old 08-14-2013, 04:55 PM   #51
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
140 degrees F at the finish line
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 08-14-2013, 05:41 PM   #52
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Ted make sure you set that window switch to shut the nitrous off before the rev limit.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 08-14-2013, 06:13 PM   #53
Supercharged SS
Drives: 2010 Camaro
Make up your own caption:
Old 08-14-2013, 06:14 PM   #54
Supercharged SS
Drives: 2010 Camaro
I think that's pretty good thing the engine was basically a flame thrower. And to think that there was still some ice in the chest when I was done!!
Old 08-14-2013, 06:25 PM   #55
Retro69
Retro69's Avatar
Drives: 2011 2SS M6 Synergy Green
Wow! Things certainly do go bad FAST!
480 rwhp ERL 416 ci with JDP Stage II Big Bore Cam
JDP tune, CAI intake, Dynatech LT headers, hi-flow cats
VMAX CNC Ported TB. GMPP Z/28 suspension package
Prothane sub-frame bushings.
Retro69 is offline   Reply With Quote
Old 08-14-2013, 06:31 PM   #56
Allanski
Drives: Car
From your first post
"They got the motor pulled and torn apart this am. It does look like then when the car hit the limiter hard, the tb closed and forced the nitrous to pack up in the intake tube. When the tb opened back up all the nitrous ran in and was dumped in the first two cylinders it found."
Could this happen with a meth injection too?
or not because the meth is not mixed directly with fuel?
Allanski is offline   Reply With Quote
