Old 08-14-2013, 06:42 PM   #57
Supercharged SS
Drives: 2010 Camaro
Originally Posted by Allanski View Post
From your first post
"They got the motor pulled and torn apart this am. It does look like then when the car hit the limiter hard, the tb closed and forced the nitrous to pack up in the intake tube. When the tb opened back up all the nitrous ran in and was dumped in the first two cylinders it found."
Could this happen with a meth injection too?
or not because the meth is not mixed directly with fuel?
Good question. I don't have the answer though. I would think it would pack up but maybe not blow up. My nitrous is dry, no fuel mixed in. The tune provides the extra fuel.
Old 08-14-2013, 08:42 PM   #58
Adadda
Drives: 2012 Camaro SS. L99
Don't take this the wrong way but everyone seems to be blaming the nitrous for the problem, but how it was used was the problem. Just don't want anyone thinking that nitrous is un safe or will cause the same problems. As a power adder dollar for dollar it can't be beat.
Adadda is offline   Reply With Quote
Old 08-14-2013, 08:47 PM   #59
Supercharged SS
Drives: 2010 Camaro
Nitrous did the damage but wasn't what started it. The excessive wheel spin did. That put everything in motion. Then the TB closed. Then the nitrous packed up, then the TB re-opened, then a shitload of nitrous entered the first low pressure area it found and melted the piston.
I have no problem with nitrous. I'll be spraying a buck twentyfive next time out. This time I'll have a whole new suspension under the car as well in hopes to eliminate the awful spinning.
Shit happens. All you can do is fix it and keep going.
Old 08-14-2013, 08:51 PM   #60
Adadda
125. To start lol I bet you end up with just a little more
Lets get that thing back together before October
Old 08-14-2013, 08:55 PM   #61
Supercharged SS
Drives: 2010 Camaro
I'm hoping to be on the track on Sept 6!!!!!! Whats a JRE rental without my car!
Old 08-14-2013, 09:01 PM   #62
jrpxxii
jrpxxii's Avatar
Yes this can happen with meth but not for the same reason as Jamies engine could have been a lot worse as nitrous could have blown the block apart but meth can cause issues if its not tuned properly or their is a malfunction with the controller as it will allow temps to spike. I had meth with my tvs2300 on my first setup and the controller went bad and so did the motor. Meth is different as it should be tuned for the cooling factor which will add power but most people think you can add meth and get aggressive with the tune but if anything goes wrong it can be catastrophic. Nitrous is the cheapest hp out there and is very safe if it used properly but can do serious damage if you don't know how to use it.
Old 08-14-2013, 09:03 PM   #63
jrpxxii
jrpxxii's Avatar
Probably a lot more fun
Old 08-14-2013, 09:04 PM   #64
Supercharged SS
Drives: 2010 Camaro
No no no. There needs to be at least one fast car!
Old 08-14-2013, 09:11 PM   #65
jrpxxii
jrpxxii's Avatar
Whatever happen to big ole lemon Ted built? aka "Ray"
Old 08-14-2013, 09:12 PM   #66
rdblan2
Drives: 2SS RS
You should track the rental!
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
rdblan2 is offline   Reply With Quote
Old 08-14-2013, 11:11 PM   #67
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
So then your car won't be there.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 08-15-2013, 01:23 PM   #68
Supercharged SS
Drives: 2010 Camaro
He's around. Just at cruise nights, not racing. Maybe in sept.
Old 08-15-2013, 01:41 PM   #69
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
We've been there before man, it's like a line up 1st. 2nd., 3rd., .... it's just a matter of time that's all.
calbert1999 is offline   Reply With Quote
Old 08-15-2013, 02:03 PM   #70
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
What are you running now suspension wise and what are you moving to? That piston had a really bad day!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
