Old 08-15-2013, 02:13 PM   #71
Supercharged SS
Drives: 2010 Camaro
Originally Posted by calbert1999 View Post
We've been there before man, it's like a line up 1st. 2nd., 3rd., .... it's just a matter of time that's all.
True. If it was the nitrous it could've been something else.
Old 08-15-2013, 02:14 PM   #72
Supercharged SS
Drives: 2010 Camaro
Originally Posted by Gotthat02fire View Post
What are you running now suspension wise and what are you moving to? That piston had a really bad day!
I was running the pfadt drag specific stuff. We popped that off to try the pedders super car coil overs. Farks is helping me with their notes and what not in setting up my car.
Old 08-15-2013, 03:42 PM   #73
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Originally Posted by Brandon@NitrousOutlet View Post
What spark plugs are you running?
Probably not the correct ones for nitrous but like SS said he doesn't want a spark plug debate.
Originally Posted by unforgiven View Post
vp c-16 = 117 motor octane
shell urt advanced= 105 motor octane
not even close in octane!
Search VP C16 vs Shell URT Advanced and see what others say. I personally have not compared the two back to back so I couldn't tell you. I use C16 in the dedicated nitrous cell and will be switching to URT-A but that is only a small portion of th hp the car makes.
What I do know is it is the highest octane unleaded currently available in all 50.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 08-15-2013, 04:01 PM   #74
SRT10KLLR
Maybe Uncle Ted can test them for us since he has a dyno and access to high hp cars.
Old 08-15-2013, 04:11 PM   #75
jrpxxii
jrpxxii's Avatar
I have run both and compared them and they are nearly identical. I am running c16 cause the shell urt is harder to get in my area. It's great if u want to stay unleaded
Old 08-15-2013, 04:17 PM   #76
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Agree with all of this.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 08-15-2013, 04:22 PM   #77
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
With a big gulp of nitrous, and all this damage, was there any knock retard on the datalog?
You do need the window switch to cut off the spray before the stock rev limiter closes the throttle blades. I didn't know the stock limiter did that. I have a LNC 2000 rev limiter set prior to just before the stock limiter. I hope it eliminates this ever happening to me!
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 08-15-2013, 05:55 PM   #78
Supercharged SS
Drives: 2010 Camaro
Zero knock. My car has never had any.
Msd window switch
Autometer tach adapter.
Old 08-15-2013, 06:32 PM   #79
SRT10KLLR
Thanks, that's exactly the feedback we need.
Old 08-16-2013, 09:47 AM   #80
H-E
Drives: 2010 zr1 Camaro 2011 vert
If you need some ideas on your rear setup ill be glad to help you out,good luck with the new bigger and better build
H-E is offline   Reply With Quote
Old 08-16-2013, 02:54 PM   #81
dan0617
dan0617's Avatar
Msd window switch
Surprised the knock sensor didn't hear anything amidst all that carnage.
Old 08-16-2013, 03:31 PM   #82
Rdunn
Really, Really Fast
Rdunn's Avatar
in reality, that all happened so quickly no knock sensor or window switch in the world would have made a difference.
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 08-16-2013, 04:23 PM   #83
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Agreed this stuff happens in Milliseconds.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 08-16-2013, 06:53 PM   #84
RBL
Drives: 2010 camaro 2SS
Originally Posted by Adadda View Post
Don't take this the wrong way but everyone seems to be blaming the nitrous for the problem, but how it was used was the problem. Just don't want anyone thinking that nitrous is un safe or will cause the same problems. As a power adder dollar for dollar it can't be beat.
Nitrous did the damage but wasn't what started it. The excessive wheel spin did. That put everything in motion. Then the TB closed. Then the nitrous packed up, then the TB re-opened, then a shitload of nitrous entered the first low pressure area it found and melted the piston.
I have no problem with nitrous. I'll be spraying a buck twentyfive next time out. This time I'll have a whole new suspension under the car as well in hopes to eliminate the awful spinning.
Shit happens. All you can do is fix it and keep going.
I think what he is saying is that if your window switch and nitrous were properly set up to begin with then this would not have happened.
www.lashwaymotorsports.com
2012 L99, whipple, Roto-Fab, Stainless Power headers, ZL1 fuel pump, cat delete.
RBL is offline   Reply With Quote
