Emblempros
Old 08-13-2013, 07:24 PM   #1
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
How much brake fluid?
So I got a GTO Clutch Resivour while at the fest and while installing I was gonna change and bleed my brake and clutch system to get rid of my old brake fluid that is 4 years old now. My question is how much brake fluid should I buy to clean out each caliper, Brake Master Cylinder, and the clutch master cylinder? Also what fluid do you guys recommend? Right now I was looking at Amsoil DOT 4 fluid but am open to any other good fluid for street use.
Proud owner of litho #179 Click Picture for Build Thread
Old 08-13-2013, 09:39 PM   #2
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
I plan to use Motul 600RBF. Plan on at least 3-4 pints to fully flush everything. Me I ordered plenty of extra. I think I have 7 or 8 pints of Motul 600RBF. I need to get to the dealership to have them do an "Autobleed" with the Tech II. That's the only way to bleed the old fluid out of the abs module. The Tech II actuates the module while they have the pressure bleeder hooked up to the car. After you do that once then you could bleed the brakes on your own in the future.
Nick S is offline   Reply With Quote
Old 08-14-2013, 01:20 AM   #3
Fast6.3
Fast6.3's Avatar
Drives: 2011 2ssrs vert 2010 silverado 6.3
you need a little over 2 pints 3 should be enough if you dont want to take it to the dealer just leave the key on that should keep the abs module active and you can bleed from there also. If you dont get it all it wont harm anything you can also buy the blue brake fluid that way when blue comes out you know for sure you got it all
[SIGPIC][tsp 2" headers no cats solo axel back magnaflow x New Era OTR Intake pfadtted suspension
H&R springs koni
Fast6.3 is offline   Reply With Quote
Old 08-14-2013, 12:04 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
2-3 pints should cover the brakes, I would add on a 4th if doing the clutch as well. We use Motul RBF600 almost exclusively. It's good stuff.
Best regards,
Tyler
888-308-6007
Old 08-14-2013, 01:20 PM   #5
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
+1 for Motul RBF 600. Buy extra so you have it when you need it.
mp51998 is offline   Reply With Quote
