BeckyD@RodgersChevrolet
Old 08-15-2013, 02:45 PM   #1
bct10985
Drives: 2010 2SS LS3, 2013 duramax
ecs pulley sizes?
Anyone know the crank and blower pulley sizes for an ecs camaro kit? Was just wondering how fast my blower is spinning. Max rpm is 55,000 for a novi 1500. Was wondering if any of u guys that have the restrictor out have thought about pulleying it down, if possible, for even more boost.
ECS Novi 1500 supercharger, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 10.41@133mph
bct10985 is offline   Reply With Quote
Old 08-15-2013, 04:53 PM   #2
bct10985
Did a little research. 7.5" crank and 3.3" blower pulley so according to vortechs calculator (assuming its the same) the blower is close to max 54xxx rpm if u shift at 5700. I overspun my old vortech s trim on a trans am. Anyone ever think about doin this?
Old 08-15-2013, 05:59 PM   #3
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
I think most people over spin those with no problems. Shifting at 5700 is weak. Take it up to 6800-7000.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 08-15-2013, 06:01 PM   #4
blake-b
blake-b's Avatar
Drives: Black 2010
I overspun my ysi without issue. Other than more power...
blake-b is online now   Reply With Quote
Old 08-15-2013, 10:59 PM   #5
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
ECS uses the smallest/efficient pulley possible. I run without the restrictor plate with no problems. You can pulley down, but it won't help at all. The blower becomes more inefficient and, if I recall, Matt did it already and it raised the IAT's. The next step would be to go to a different blower, which would be the YSi.
Over the winter months, that is one of the things that I plan on doing.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 08-19-2013, 03:10 PM   #6
East Coast Supercharging
East Coast Supercharging's Avatar
Drives: 8 second C5 Drag Car, C6 Road racer
I am more comfortable with over spinning the oil fed units like the YSI, but the self contained units I would not recommend going too much over the recommended RPM.
East Coast Supercharging is offline   Reply With Quote
