Solo Performance
Old 08-15-2013, 10:23 PM   #1
SemperGumby
I'll probably offend you
SemperGumby's Avatar
Drives: 2013 2SS/RS M6
Question Hood not lined up
Ok, so I removed the metal plate behind the front bumper in order to access the front bowtie emblem (Plasti-Dip YEAH!) and after replacing everything my hood now latches a good 1/2" below the lip of the bumper. I've adjusted the bumper stops to no avail, what else am I missing here?
SemperGumby is offline   Reply With Quote
Old 08-15-2013, 10:26 PM   #2
Squillo
Squillo's Avatar
Drives: 2013 Camaro 2SS/RS BRM LS3
Pictures?
Performance
AirAid CAI
Apex Motorsports ported spiraled Throttle Body
Kooks 1 7/8" LT headers and 3" mid-pipes (cat delete)
Hurst shifter
Dyno Tune
Cosmetic
Camaro badge GOBO door lights
"SS" badge GOBO hood and trunk lights
Blacked out side markers with 30% tint
Blacked out tail lights with 30% tint
Afterburner tail lights
Blue / white color changing headlight and foglight HALOs
Blue LED upper and lower grille accent lights
30% tint windows
Plasma fog light bulbs
DRL harness
"BDMFER" Hawaii state issued license plates
"Bad Mother****er" custom blue lighted door sills
Blacked out bow ties
Squillo is offline   Reply With Quote
Old 08-15-2013, 10:32 PM   #3
SemperGumby
Good call... Left side of the pic is the hood, right side is bumper.
Old 08-15-2013, 10:44 PM   #4
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
I want to say I read another thread saying there are screws that set the gap for the hood. Not sure if they're the same holding the plate. If they are, maybe you just threaded them too deep and need to adjust.
bluBlud is offline   Reply With Quote
Old 08-15-2013, 10:46 PM   #5
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
Correct...the hex ones....
Glen e is online now   Reply With Quote
Old 08-15-2013, 10:46 PM   #6
Squillo
Squillo's Avatar
Pics with the hood open too please?
Performance
AirAid CAI
Hurst shifter
Dyno Tune
Cosmetic
30% tint windows
DRL harness
Old 08-15-2013, 10:47 PM   #7
SemperGumby
So the 4, I think it's 4, hex ones need to be loosened up in order to set the correct height?
Old 08-15-2013, 11:04 PM   #8
SemperGumby
Just went out and adjusted again, loosened all 4 of the socket bolts, and the 2 hex ones, and with them all completely loose the hood was nearly perfectly flush. After tightening them all back down to just hand tight then a 1/4 turn past the hood now sits about 1mm lower than flush... da hell?
Old 08-15-2013, 11:09 PM   #9
yellowrs
Drives: 2010 SS 426 V8 M/T
That is one sharp picture
yellowrs is offline   Reply With Quote
Old 08-16-2013, 11:13 AM   #10
Hurst
Camaros Of Northwest Ohio
Hurst's Avatar
Drives: 2013 SIM 2SS/RS, LS3
Only adjust the star screws. I believe the the bolts are 10mm. Tightn and leave them. The star screws adjust the front piece. Loosening them will bring it down, tightening them will raise it. If you adjusted the rubber hood stops, you may have to readjust them as well.
Hurst is offline   Reply With Quote
Old 08-16-2013, 04:18 PM   #11
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Yeah... the Torx-head screws raise and lower the top of the fascia. Bumpers should be for minor fine adjustments everything else should be tightened right down.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
