Old 08-16-2013, 11:51 AM   #1
wheelio
Banned
Drives: camaro v6
Speaker Question/Warranty
Lately I've been turning the volume on the radio all the way up and playing a song with the best bass I can fine. Normally I keep the radio very low but a neighbor has been acting out lately so I've decided to be annoying as well. My question is what are the chances of the speakers blowing? This would be covered under the bumper to bumper warranty correct?
wheelio is offline   Reply With Quote
Old 08-16-2013, 01:49 PM   #2
suzook
Drives: camaro
There is a very good chance you will blow it. Yes...covered by bumper to bumper.
2016 2SS,A8,NAV,NPP,MAG Ride,Sunroof
Hyperblue/JetBlack
suzook is offline   Reply With Quote
Old 08-16-2013, 03:34 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Right and wrong.
Yes most likely you will blow the speaker but if it was determined that the was blown out of abuse, like turning the volume up really loud, it will not be covered.
Old 08-16-2013, 03:47 PM   #4
jkchambless
Austin LT
jkchambless's Avatar
Drives: 1LT - Airaid,JBA Axleback,VMax PTB
How is turning up your stereo to the max considered "abuse"....the speakers should be rated for whatever the system can push through them.
jkchambless is offline   Reply With Quote
Old 08-16-2013, 03:57 PM   #5
wheelio
Banned
Drives: camaro v6
Agreed
Old 08-16-2013, 04:32 PM   #6
TwistedEnergy
TwistedEnergy's Avatar
Drives: 2010 IOM 2SS/RS
I blew my left front lower speaker (driver door)...never had volume above 35, most of the time its at 22 to 30. It happened after my warranty had expired and I was even contemplating getting the extended warranty. So now it pops at anything with a lot of bass and the volume above like 23. So I have to turn the bass all the way down to like -3 on the EQ to be able to get more volume.
Just thought I would share, as you can see it is very possible to blow the damn speaker even under normal conditions.
TwistedEnergy is offline   Reply With Quote
Old 08-16-2013, 05:13 PM   #7
wheelio
Banned
Drives: camaro v6
can anyone please clarify this issue?
Old 08-16-2013, 05:23 PM   #8
~ChipsAhoy~
Shenanigans
~ChipsAhoy~'s Avatar
Drives: 2010 CGM 2SS/RS L99
It would be the same as running your car at redline for long, extended periods of time. Something eventually has to give.
To answer your question, no it would not be covered under a factory bumper to bumper warranty if you state you had the music cranked. That would be classified as "Negligence." Now, if you stated you had it up at 18-20, not max, and it blew...then that might be a different story.
2010 CGM 2SS/RS L99
~ChipsAhoy~ is offline   Reply With Quote
Old 08-16-2013, 06:16 PM   #9
jkchambless
Austin LT
Just curious, but how can you definitively answer this question....experience? Specifically stated in the warranty? Head of customer service for GM? Warranty school of Nod Nod Wink Wink?
Old 08-16-2013, 06:20 PM   #10
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
Correct answer.....at least with the car mfrs I worked with, handling warranty issues....
Glen e is online now   Reply With Quote
Old 08-16-2013, 06:29 PM   #11
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
And they probably are. Problem is, you start clipping the amp when you turn one up all the way, then you're sending distortion to the speaker, which shreds the voice coil.
That's pretty basic stereo knowledge. Never turn one up all the way, and turn it down if you hear distortion that's not meant to be there.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 08-16-2013, 06:56 PM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Holy crap. Are you deaf or have hearing problems?
Mine never goes above 14 because above that is just too loud for everyday use, most of the time it's at 12 or 13. The db's that is put out at 20+ doesn't fall under normal use. No wonder your speaker blew.
Just because something "can" do something, doesn't mean that it can maintain it and do it often enough, it will break. You car can run at 6.5k rpms but if you drive it like that too much eventually you will need a new engine. It's the same thing with speakers.
Old 08-16-2013, 07:30 PM   #13
wheelio
Banned
Drives: camaro v6
Can anyone provide a reputable source to back up their claims?
Old 08-16-2013, 07:32 PM   #14
jkchambless
Austin LT
I understand and am not disputing that on most stereos there is inherent distortion at the top of the range that can cause speaker problems. My issue is saying that the bumper to bumper warranty won't cover a "blown" speaker unless I lie about it. That and the fact that some people answer questions as if they are experts about a particular subject and not just giving an opinion. If I am on the wrong side of this, well, it's just my turn to be an a$$h0l3.
