Old 07-08-2009, 08:21 AM   #1
Augie1978
Augie1978's Avatar
Drives: 2011 2SS RS Vert
Need wiring alernative for radar detector
I am looking for a way to wire my radar detector to a power source in the rear view mirror/dome light. Has anyone done this yet? I like the looks of having the radar detector next to the rear view mirror attached to the top of the windsheild but am getting tired of looking at the power cord draping down to the console outlet.
2SS RS, Triple Black Vert, Manual, Hurst Shifter. American Racing Headers, Roto-Fab CAI
Augie1978 is offline   Reply With Quote
Old 07-10-2009, 06:15 PM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
not to long ago I was looking for a new detector and I ran across onje that and an accessories set up just like you decribt some does make that set up.
Old 07-10-2009, 09:29 PM   #3
Sir Nuke
Sir Nuke's Avatar
I looked around and found this, the Invisicord, you have power to the rearview mirror, and if you use a mount up by the mirror, AND if you have one of the following detectors, you are set.
Escort 9500i, 8500, X50, 7500, 6800, Solo S2
Valentine V1
Beltronics STi Driver, Pro RX65, Pro RX55, Vector 995, Vector 965, Vector 955,
Vector 940 (phone style connector), and Express 795
Basically any detector that uses the Escort/V1 Smartcord for power for above brands...
Old 07-10-2009, 10:08 PM   #4
LyssaRaen
LyssaRaen's Avatar
Drives: 2010 SS/RS SIM W/ CGM Stripes
Mounted mine at the top of the windshield next to the mirror. Tucked the cord along the top of the windshield and ran the cord down the A pillar and tapped into power at the auxillary outlet in the console. Works great!
LyssaRaen is offline   Reply With Quote
Old 07-22-2009, 11:30 PM   #5
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
Are any of you putting in a gps? I have a little garmin but can't decide where I want to put it.
I was thinking about the A pillar. but then I will have to run the chord a ways under the dash and everythign to the cig lighter.
Anyone have any ideas?
Near the mirror is too much. There's not enough vision as it is.
Li0nel1234 is offline   Reply With Quote
Old 08-03-2009, 09:35 PM   #6
Van
Van's Avatar
Drives: 2006 EVO MR - 390 @ wheels
Are you all taking off pieces of the dash to do this? I have a V1 but don't want to be taking off interior pieces that snap on or off....only ones that have screws.
Isn't there anything in terms of un-used fuses and such that can be tapped into using the fuse taps you buy at auto-zone?
2010 2SS/RS 6spd manual -- Victory Red / Black Leather
1100, Preliminary order accepted 7/27/09
2000, Order accepted by GM 8/13/09
3000, Order accepted by production control 8/18/2009 TPW 9/07/2009
3300, Order scheduled for production 8/24/2009
3400, Order broadcast 9/1/2009
3800, Order produced 9/11/2009
4200, Shipped 9/11/2009
5000, Delivered to the dealer
Van is offline   Reply With Quote
Old 08-30-2009, 11:22 PM   #7
Cmurf_SS
"SLOMARO"
Cmurf_SS's Avatar
Drives: 2010 2SS/RS
Might sound distracting, but on long road trips, I mounted my gps right onto the stereo face, there is a little flat spot on the uppoer left that will take most of the universal cups.. easy access.. More permanent solution .. dunno yet.
Dyno'd before VARARAM TUNE unit at 390hp
Cmurf_SS is offline   Reply With Quote
Old 08-31-2009, 02:31 PM   #8
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
I used the "Invisacord" (12") for my V1. Tapped into the power wires that run into the mirror. Works great, easy install. You just need to pull off the plastic cover that hides the wires...and plug 2 wires into the harness.
I'll double check which wires and post it later.
2010 R6P-2SS/RS/LS3 - Paxton, 9" rear, 625rwhp, IBM w/ silver rally stripes, FOR SALE!
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 09-20-2009, 07:32 AM   #9
600hp-lpe
Drives: 2010
I am about to do this (once my car is home). I would like to know which wire is power, and which is ground on the back of the mirror. Thanks!
600hp-lpe is offline   Reply With Quote
Old 09-20-2009, 12:19 PM   #10
POWERFREAK
I.AM.
POWERFREAK's Avatar
no problem...here goes...
There's a connector behind the mirror (remove the plastic cover). Use the end that's facing the floor. The ground is white w/ a black stripe. It's all the way on the passenger side of the connector. The + lead is RED and it's in the same row as the ground (a few wires over).
It's kind of a pain to get to and see. I removed my mirror and disconnected the wiring to make it easier. The invisacord ends fit real nicely in the wire connector. Well worth the $16.
For anyone else interested...here's the link...
http://invisicord.com/osc2/catalog/p...e66d953507ad63
NY5thgen.com
Old 09-20-2009, 02:22 PM   #11
600hp-lpe
Drives: 2010
Cool - Thanks for the info. I have the invisicord already. that, with the blendmount and a peice of velcro adn I will have a good mount for the V1. All I need is my car...
Old 09-27-2009, 08:56 PM   #12
ZombieEatsYou
ZombieEatsYou's Avatar
Drives: "Bmblbee" 2010 RY 2SS/RS. VIN 12043
I went to 3 different stores and all their fuse taps were way too big to fit. I might have to go to the invisicord route.
ZombieEatsYou is offline   Reply With Quote
Old 10-07-2009, 01:19 PM   #13
NightStash
NightStash's Avatar
Drives: 2SS/RS RJT, 2002 WS6 Tran-am
What length Invisicord did you order?
NightStash is offline   Reply With Quote
Old 10-07-2009, 01:29 PM   #14
POWERFREAK
I.AM.
POWERFREAK's Avatar
I got the 12"...it's long enough to mount it next to the mirror, up towards the top of the windshield.
NY5thgen.com
Garmin nuvi > mounting & wiring for the Camaro 67 GTO Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 25 11-05-2011 01:52 PM
Anyone have picts/info on the factory infotainment system wiring harness & plugs? Matt'sSS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 10-01-2009 01:48 AM
Radar Detector Hardwiring? - Tapping into 12V Accessory Sloppy Joe Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 0 06-23-2009 03:18 PM
Hardwire Radar Detector? mhennick Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 06-13-2009 11:27 PM
Radar detection systems? DGordon Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 68 04-02-2009 10:05 PM
