Old 08-16-2013, 04:19 PM   #1
pdiddy
Drives: 2011 2SS
air fuel ???
So I recently put a wide band gauge on the car and punched out my cats when I had the car dynoed about a month ago my air fuel was 11.8 pretty much accross the board however since punching out my high flow cats and installing my gauge the gauge reads 10.8 its a prosport gauge any ideas? did the cats change this or is there something I need to know about these gauges car seems to run pretty much the same as before
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 08-16-2013, 04:22 PM   #2
pdiddy
Drives: 2011 2SS
just fyi the 11.8 reading came from the wide band on the dyno..
Old 08-16-2013, 04:52 PM   #3
pdiddy
Drives: 2011 2SS
Another FYI when it was dynoed it was a sniffer that was used for af not a wide band as I didnt have a wide band then
Old 08-16-2013, 07:48 PM   #4
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
Pull the O2 sensor and hang it so it is in clean air. Then push and hold the little button on the side of the controller box for 3 seconds until the gauge reads "2", this will indicate that it is calibrating. When complete, replace the sensor in the exhaust stream.
If that doesn't work order a new sensor from Prosport. Part number is 17025.
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 08-16-2013, 08:22 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
If you had the WB post cat it'll read a few % lean compared to what it measures pre cat. The cats were working. Since you punched them WYSIWYG.
Iam Broke is offline   Reply With Quote
Old 08-16-2013, 08:27 PM   #6
pdiddy
Drives: 2011 2SS
What I had for readings before was from a sniffer at the end of my exhaust at the dyno it read 11.8 pretty constant during dyno and made good hp since then I punched out the cats and installed a wide band just where one of the 02 sensors plugged into the cat which is now hollow am getting 10.8 at wot reading consistent I did recal in open air but same results so I don't know wat to think
Old 08-16-2013, 08:33 PM   #7
Unreal
Drives: 2006 Z06
Sniffers usually ready 1/2 point leaner than up by the header.
Nick
Corvette Z06 -1200ish rwhp
Old 08-16-2013, 08:49 PM   #8
pdiddy
Drives: 2011 2SS
But i would think if I was a whole point off I would not have made the 540 rwhp I did with the Maggie 3.8 pulley and bolts on I have but I don't know how much a point rich would affect my hp numbers
Old 08-16-2013, 08:51 PM   #9
pdiddy
Drives: 2011 2SS
I may pull a plug and take a look at it maybe post a picture and see what people think
