sjm autoprod
Old 08-16-2013, 08:01 PM   #1
1sicss
1sicss's Avatar
Drives: 2011 camaro 2ss/rs
posi rear end
do the ss's have a posi rearend
1sicss is offline   Reply With Quote
Old 08-16-2013, 08:37 PM   #2
monicatomokc
monicatomokc's Avatar
Drives: 2014 Corvette 2012 Yukon Denali
Yes, as do the V-6 models with manual transmission.
monicatomokc is offline   Reply With Quote
Old 08-16-2013, 09:14 PM   #3
1sicss
1sicss's Avatar
what about the auto's I did a couple of burnouts recently and only seeing one mark but I was turning slightly
Old 08-16-2013, 09:25 PM   #4
Supercharged SS
Drives: 2010 Camaro
The posi in these cars is weak. Most do a one wheel burnout. Lookup the Jannetty Posi mod. That's the way to fix it.
Old 08-16-2013, 09:30 PM   #5
1sicss
1sicss's Avatar
thanks was a little embarrassed was showing off at work, and only got one to leave a mark then today I got where's the posi. will have to add this to my list of mod's for when I take it to jannetty
Old 08-16-2013, 09:59 PM   #6
Supercharged SS
Drives: 2010 Camaro
Just imagine how I felt in the beginning of 2010 doing the one wheel peel at the track with 550 rwhp!! Thankfully Ted was there and developed the fix.
Old 08-17-2013, 11:11 PM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
So then, how do you feel now?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
