JUICEDMOTORSPORTS
Old 08-17-2013, 10:19 AM   #1
Motion427
Drives: 2010 2SS/RS Red Jewel L99
quietest exhaust for 600+rwhp
I'm working on a TVS supercharged Camaro at the shop right now.
It has JBA long tube headers, small cats and stock exhaust.
Engine has forged pistons,rods,and crank.
We are checking the motor out and upgrading the valvetrain for something more TVS supercharger friendly.It still ran the stock valvesprings and trunions
Currently the boost is set at 10-11 psi.Will probably keep it there for now.
I know I have to remove those darn cats.
Did anybody have made 600-650 rwhp (M6) with the stock exhaust?
Or is their something else that is out there that would flow better,but also as quiet? Customer does not want to draw attention.
Just asking for opinions.
Thanks in advance.
Motion427 is offline   Reply With Quote
Old 08-17-2013, 10:33 AM   #2
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
My Corsa is very quiet at idle and cruising yet sounds different and to me a lot better than most exhaust I've heard personally. At WOT it gets LOUD.
DarkCry956 is online now   Reply With Quote
Old 08-17-2013, 10:36 AM   #3
Motion427
Thanks DarkCry956.Corsa is a great exhaust.Do you have the sport or the touring model?
Worse case.Could even install a L99 exhaust instead. But will the performance be there????
Old 08-17-2013, 10:38 AM   #4
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Magnaflow street is a tad quieter than anything else out there, but just a tad. The car will be loud.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 08-17-2013, 11:02 AM   #5
mcdoogle6969
mcdoogle6969's Avatar
Drives: 2010 Camaro SS, 2008 Heritage 300C
I'm running 2x3" ARH's and the quieter borla series axle-back, everything in between was custom made and also have cutouts...So I get a nice growl for when I don't want to be bothered by the police, and insanely loud when I want to give myself a heart attack.
Either way, unless you really muffle down the entire exhaust, it will be "loud" to a certain point at those power levels.
mcdoogle6969 is offline   Reply With Quote
Old 08-17-2013, 11:15 AM   #6
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Solo Mach XL J pipe system is reasonable at light throttle under 2k rpm with headers, catless. It barks loud WOT though. I love it as there is zero drone now. I had a 3" MBPR system x piped and swapped out the x for the resonated H and the drone still killed me 1400-1700 rpm.
As was posted above, it's gonna be loud under load no matter what. My wife commented on how much quieter it is now, she doesn't hear me leave or come home like she used too. The j pipes really work at low RPM.
Iam Broke is offline   Reply With Quote
Old 08-17-2013, 11:33 AM   #7
DarkCry956
DarkCry956's Avatar
I got the regular Corsa for an L99. I don't think they had touring or sport when I got my setup. I think sport and touring are for the ZL1 actually but I don't know. I've gone from long tubes to Cam to Blower and its always been quiet at idle and cruising.
Old 08-17-2013, 11:38 AM   #8
BooSSted
BooSSted's Avatar
Drives: 2017 Z06 / 2012 CTS
+1 on the Solo Mach XL exhaust, I have LTs with my Maggy. Mellow under 2K and at idle. When you get into it though it has a very nice clean tone, one of the best i've heard.
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06
BooSSted is offline   Reply With Quote
Old 08-17-2013, 12:21 PM   #9
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
I know its not a camaro, but my buddy has a twin turbo V8 lexuas SC400. He was the same way to where he wanted to keep it quite. So he has no cats on the car, but lined up 6 total mufflers (3 on each side). Now its got a little rumble to it, but is super quite. He put down over 550whp with it setup this way too. So it can be done, and i am sure if he took a few of the mufflers off he might make a little more power. But it amazes people how quick the car. My camaro stock with stock exhaust was louder than his car.
xjer22x is offline   Reply With Quote
Old 08-17-2013, 12:46 PM   #10
injector
injector's Avatar
Drives: LS3
Magnaflow street series + magnaflow x resonated pipe + ARH 1 7/8 LT+ custom j pipe and my LS3 (830 rwhp) is super quite.. All i hear is the d1 pulley turning...
Texas Speed & Performance Custom Built Forged 408 CID, PRC LS3 260CC,Fast Intake & NW 102 TB, Alky Methanol kit, ID850, LPE Dual pumps,,Melling HV oil Pump. D1SC 10PSI, Stage 2 Air Intake,Magnaflow Axle back, Mcleod clutch, Pedders XA coilovers and sway bars, HD bushings, Hurst shifter, ACS bumper and hood ports, DSS aluminum drive shaft, CSF radiator .
injector is offline   Reply With Quote
Old 08-17-2013, 12:57 PM   #11
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
I have the stock a6 exhaust with 2" headers no cats. Quietest possibility at that hp..
K32 Camaro is offline   Reply With Quote
Old 08-17-2013, 03:57 PM   #12
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
I kept the stock mufflers, quiet as a church while cruising, Loud enough when you hit it.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - Granatelli Brake Lines - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 08-17-2013, 04:04 PM   #13
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
NPP and keep it closed with an ADM module or stock mode for permformance.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 08-17-2013, 04:08 PM   #14
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Yea stock but that will rattle a bit. I went with Borla Touring exhaust. With my Kooks 1 7/8 headers and off road pipes it sounds good not to loud but dose come alive at WOT.
Slickcas is offline   Reply With Quote
