Jason 98 TA
Old 08-17-2013, 02:11 PM   #1
Andymon
Andymon's Avatar
Drives: TwinTurbo 2012 IOM Camaro 2SS
Need help with suspension upgrade (experience and opinions)
Hello everyone. I have gotten a lot of help from the vendors on here but now am looking for help from my fellow forum members. Please give me your option on my options as well as if you have done the same thing.
Let me start by outlining what I am looking for. I want to upgrade my suspension for my new found power level of around 600rwhp. I do not auto-x or take the car to the drag stip and I do not want to drop the car very much. I plan on keeping it around oem ride height or maybe 0.5 drop. I want something that will support my power level, reduce wheel hop, and leave my ride quality oem or better.I am looking for an upgrade on handling for spirited street driving as well. Pretty much a better feeling ride. I got the chance to drive a ZL1 and felt the difference. Now I know the SS is not to that level but hope to close the gap somewhat.
So in short I hope to:
Uprade handling for spirited driving
Reduce wheel hop
Reduce body roll
Keep oem or better ride quality
Replace the week points in the FE4 suspension
Have a strong foundation for 600rwhp.
Now here are the parts I am considering in order:
27/32mm swaybar set
Subframe bushing
Radius bushing inserts
Upper control arm bushings
ZL1 Toe rods
Trailing arms with bushings
Xa coilovers
Alignment Bolt kit
Now here are some of the questions I am hoping to answer:
If you have done how has the items changed your vehicle both good and bad? How has oem ride quality changed? Over bumps and rough roads?
What parts would I notice the best "bang for my buck"?
What parts would you recommend getting for a fair weather fun car that doesn't need every performance or handling advantage possible?
Would coilovers be overkill or a waste of money for what I am looking to get out of my car?
Again no track use in mind. Thanks for any help.
Andymon is offline   Reply With Quote
Old 08-17-2013, 02:49 PM   #2
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
I know you asked for some Members help but I wanted to also throw in my suggestion.
Pfadt Stage 3 kit!!
http://store.pfadtracing.com/camaro-...e-kit-stage-3/
This kit has pretty much everything you need. It stabilizes the rear end during hard launches, plants the power to the ground, eliminates wheel hop, and limits alignment changes that typically takes place under load.
We just installed this kit on a Whipple Supercharged SS and I have to say, it was a completely different ride!
PM or Call me with any questions.
Thanks
JT
Team STILLEN is offline   Reply With Quote
Old 08-17-2013, 02:54 PM   #3
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2013 SS 1LE
You asked about best bang for your buck. If you're not hitting the track, your list looks like a pretty expensive upgrade and it would probably be overkill if you did everything.
You could probably reduce the list just to lowering springs and a rear sway bar. Maybe add a couple of bushings for the 600 RWHP, not sure which would be best. Since you're looking for OEM or better ride quality, try to find springs that are not too low or too stiff (they go together). In any event, you will end up with a stiffer ride and it won't be as good as OEM ride quality. But the reward is better performance.
My Camaro's primary purpose is the road course, so I am springing for Supercar coilovers, but that was a hard decision. A lot of labor and expensive parts. If I didn't track, I wouldn't do coilovers.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 08-17-2013, 02:56 PM   #4
Orange Crush 1LE
Drives: 2013 SS 1LE
Pfadt Stage 3 kit!!
Thanks
JT
Exactly, something like this would be ideal. A lot less expensive than coilovers and the rest of your list.
Old 08-17-2013, 03:01 PM   #5
Andymon
Andymon's Avatar
I would do coilovers before lowering springs. I don't want that much of a drop. Also would probably go the pedders cradle bushings over a solid one.
Old 08-17-2013, 03:07 PM   #6
Orange Crush 1LE
Drives: 2013 SS 1LE
The ZL1 springs lower the car but not as much as the typical lowering springs. Worth looking into. Just make sure you price the labor too, I had sticker shock when I found out how much it costs to have coilovers/bushings/sway bar done by a reputable shop. I guess it depends on budget. If you have a big budget, coilovers are the best solution.
Old 08-17-2013, 03:38 PM   #7
Andymon
Andymon's Avatar
I don't have a huge budget. Kind of don't want to spend a ton...already did that on go fast parts. My thinking was to do as much as I could all at the same time to save on labor and another 90 minute trip to the pedders dealer. Mind if I ask how much you spent on your setup?
Old 08-17-2013, 03:56 PM   #8
Orange Crush 1LE
Drives: 2013 SS 1LE
Sure, I'll PM you the details
Old 08-17-2013, 04:03 PM   #9
Andymon
Andymon's Avatar
Thanks. I don't plan to do anything with the shocks/struts/springs unless I go all the way and do coilovers. With coilovers I would keep it close to stock right height with damping set lower for comfort.
Old 08-17-2013, 10:31 PM   #10
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Andy,
Have you read this yet?
http://www.camaro5.com/forums/showth...s+5th+gen+book
Start there.
Then call Bruce at Raymonds Performance in Indy, since he is the closest to OH, and talk to him about your goals. He is a vendor on here.
http://www.raymondsperformance.com/
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 08-17-2013, 10:51 PM   #11
Andymon
Andymon's Avatar
Originally Posted by TBone View Post
Andy,
Start there.
T.
Thanks Tbone. Yes I have ready "the book" on suspension. My main question right now is are coilover worth the cost on a street only car that seems to only do spirited runs from time to time.
Old 08-17-2013, 11:32 PM   #12
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
I think the simple answer to that question is no, to be honest. For someone who only does spirited street driving, a few bushings, springs, and sways are more than enough for street duty.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 08-18-2013, 01:17 AM   #13
Andymon
Andymon's Avatar
And that's what I was looking for. I am not getting springs so I guess I should leave the stock stuff alone.
Old 08-18-2013, 10:51 AM   #14
Andymon
Andymon's Avatar
Any other input?
