JDP Motorsports
Old 08-18-2013, 09:05 PM   #15
Andymon
Andymon's Avatar
Drives: TwinTurbo 2012 IOM Camaro 2SS
Added some questions.
If you have done how has the items changed your vehicle both good and bad? How has oem ride quality changed? Over bumps and rough roads?
Andymon is offline   Reply With Quote
Old 08-18-2013, 10:13 PM   #16
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2013 SS 1LE
I thought I should add that, for traction to support your goal of 600 RWHP, it's typically better to have a soft suspension to allow weight transfer. Once you stiffen it with coilovers, you will likely hook up less. Lots of other factors though. So for that reason, sticking with the stock springs but beefier sways and bushings seems best.
I had a 630HP '95 Camaro, it was downright dangerous with the Eibach Sportline (if I remember right) springs/shocks, I could smoke the tires at 60+MPH accidentally. So I swapped out that suspension for drag suspension (soft springs and shocks in front, special torque arm, 315 drag radials, Etc.). Then it hooked up like nobody's business.
The more I think about it, you may want a 1LE-like suspension. Not lowered, handles fantastic, not too stiff. You could mix and match OEM and aftermarket stuff. I'd probably do Pedders sway bars, 1LE OEM shocks, plus some key bushings. You will not believe how well it handles, and traction is decent.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 08-18-2013, 10:18 PM   #17
Rob@WretchedMS
Drives: His Wife Crazy
Just wanted to jump in,
Actually that is not correct.
On solid rear axle cars that is 100% correct, however on IRS car's like the 5th Gen Camaro it's best to control the rear of the car from compressing. If you allow the rear of the car to compress, you also allow negative camber to increase, and thus the contact patch of the tire goes away. On a Camaro to launch best you want to keep the rear of the car at a level that the Camber doesn't go too negative.
Rob@WretchedMS is offline   Reply With Quote
Old 08-18-2013, 10:24 PM   #18
Orange Crush 1LE
Drives: 2013 SS 1LE
Interesting Rob, thanks. I didn't realize, but it does make a lot of sense.
So how do you get traction with IRS? What do the guys do when they are focused on straight line performance?
Old 08-18-2013, 10:31 PM   #19
Rob@WretchedMS
Getting the rear of the car down is important, but with the stock alignment bolts you can't get the camber near 0. This is where the Pedders alignment bolts come in, as they allow more adjustment, and can typically get the rear camber at or close to zero while still allowing it to be lowered a bit. Sometimes even getting the camber a bit positive works well too for straight line.
Xa Coilovers are helpful in this situation since you can not only adjust the height where it works best, but you can stiffen them up to help in the launch.
Supercar Coilovers are even better with this since you can adjust the compression and rebound independently, helping even more.
Old 08-18-2013, 10:35 PM   #20
Rob@WretchedMS
I think what Andymon is looking for is people that have the parts on their car, and how they feel about the differences in ride quality vs stock.
Old 08-18-2013, 10:37 PM   #21
Andymon
Andymon's Avatar
That sounds like an idea. I was thining about piecing things together.
Old 08-18-2013, 10:37 PM   #22
Andymon
Andymon's Avatar
Yes thank you.
Old 08-18-2013, 10:37 PM   #23
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Rob is Da Man too!!!!
And yes coilovers are worth it on the street, like Rob says, for the reasons stated.
On vacation guys but will be back later this week. In the mean time listen to Rob.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 08-18-2013, 10:40 PM   #24
Rob@WretchedMS
I would not install 1LE shocks if you want the ride quality to remain about the same as the stock SS. The 1LE shocks are stiffer and less compliant than the SS shocks are.
I would stick with the stock shocks or do coilovers, but not the FE6 shocks from the 1LE
Old 08-18-2013, 10:49 PM   #25
Andymon
Andymon's Avatar
T.
Yes I know...he is the man!!
Old 08-18-2013, 10:55 PM   #26
TBone
TBone's Avatar
He is slow, but helpful.
T.
Track fix.
Old 08-18-2013, 10:56 PM   #27
Rob@WretchedMS
my head is going to explode if it inflates more, lol
Old 08-18-2013, 10:57 PM   #28
Rob@WretchedMS
T.
......faster than you,,..
doh! lol
