ADM PERFORMANCE
Old 08-17-2013, 04:56 PM   #1
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro 1ss/rs
How many of you.......
For those of you running just over 600rwhp, did you change internals on motor, if you didn't how's your car holding up you have any issues? I'm looking to go fi on my Camaro and I'm just wondering at that power level how are things holding up.
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 7/8" LTH w/ deleted cats, corsa exhaust, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, fully forged 416ci stroker all installed and dyno tuned by slowhawk performance.
lakersftbl69 is offline   Reply With Quote
Old 08-17-2013, 06:04 PM   #2
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Stock bottom end making over 740 rear wheel horsepower. I'll build it at some point but plenty people making over 600 with a good time and fuel.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 08-17-2013, 06:23 PM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
i ran at 637 whp for a while and got greedy. Pulley'd down and added meth and beat severly on the car for 6 weeks at 715whp and broke the top 2 ringlands on #5. That was my plan.....too see how much abuse the stock bottom end could take. 6 galllons of meth in those 6 weeks.
I had my new motor already in the process of being built when i ran this experiment. I think it would have run a long time if i wasnt doing 1st-4th pulls every day to and from work.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 08-17-2013, 07:28 PM   #4
lakersftbl69
Wow lol so it seems like just over 600 they seem to be holding up pretty well.
Old 08-17-2013, 07:44 PM   #5
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Most of them do, I'm still doing a 417 build in November though
MODS:
Old 08-17-2013, 08:25 PM   #6
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
They're are people running 900+whp on the stock shortblock w/o a problem
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is online now   Reply With Quote
Old 08-17-2013, 08:37 PM   #7
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
It's not a question of how many, it's how long.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 08-17-2013, 08:42 PM   #8
timtoolman24
timtoolman24's Avatar
Drives: 2012 LS3 2SS/RS
I been running 720 for almost a year now with all stock internals. No problems. I believe its all in the tune and also how you the driver takes care of it. But sh** does happen. Near future plan is to add meth and then forged internals before adding more boost or something else
timtoolman24 is offline   Reply With Quote
Old 08-17-2013, 09:22 PM   #9
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
600+ here & no problems. Over 5000 hard miles on stock short block.
It's in the tune & components (fuel etc)
But remember anything can go wrong at anytime..
2017 ZL1 A10: Bone Stock.
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 08-17-2013, 10:37 PM   #10
lakersftbl69
Thanks for the Info everyone
Old 08-17-2013, 10:48 PM   #11
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
I'm running with stock internals myself, however I don't push my luck too often.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 08-17-2013, 11:01 PM   #12
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
650 to the wheels. 6000 miles in the last year. No problem's yet.
FWIW, I just knocked on wood. Lol
Sent from my HTC One X using Tapatalk 4
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 08-17-2013, 11:16 PM   #13
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
700+RWHP here. A little playing around on the street but a lot of 1/4 mile runs and no problems so far
DarkCry956 is offline   Reply With Quote
Old 08-18-2013, 01:03 AM   #14
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Was running over 620whp with a rear mount twin turbo setup for almost 3 years. Over 80 trips down the strip, best pass being a 10.99 with stock suspension, rear end, and tranny.
Just recently blew the ringland on cylinder #7. Signs of it running lean. I feel if i had a better tune at the time i would still be kicking.
So as others have said, good tune and plenty of fuel. and you can enjoy it for some time.
xjer22x is offline   Reply With Quote
