Old 08-18-2013, 11:33 AM   #1
intensifi
Drives: '12 2LT Convertible
How do you strip the chrome off the badges/bezels?
I'd like to go down to the base plastic before I start the painting process.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 08-18-2013, 12:26 PM   #2
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
You are going to have to sand them and end it with 2000 grit.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 08-19-2013, 01:14 AM   #3
intensifi
bleach seems to be the way to go.
I found this solution via a google search,
NOTE: If you use bleach make sure to do it OUTSIDE and use proper PROTECTION (mask and gloves).
Old 08-19-2013, 07:49 AM   #4
bumblebeecamaro
Car Lover By Nature
Drives: Mini Cooper S
bleach removes chrome from plastic?
bumblebeecamaro is offline   Reply With Quote
Old 08-19-2013, 09:12 AM   #5
intensifi
Yes. It takes a while.
It appears best results are achieved if you sand through most of the clear coat first.
Old 08-19-2013, 12:17 PM   #6
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
hmmmmm that's news to me, thanks for that.
Old 08-19-2013, 12:37 PM   #7
~ChipsAhoy~
Shenanigans
~ChipsAhoy~'s Avatar
Drives: 2010 CGM 2SS/RS L99
Just painted my bezels last night.
I just sanded them with 1000 grit so the paint would have something to adhere to, cleaned the dust and other loose impediments off with a alcohol/water mix. Most of the chrome was still on there when I started spraying them. However, I did spray them with some Valspar plastic bond before spraying my base coat and then high gloss clear. I let them sit for a couple of hours and then installed them. I figure if they end up looking like crap (which I don't think they will, but maybe I am wrong), then I can just find a set somewhere and start over with a different process. It may not have been the right process, but it worked fine for winging it.
2010 CGM 2SS/RS L99
~ChipsAhoy~ is offline   Reply With Quote
Old 08-19-2013, 12:49 PM   #8
intensifi
I'm sure it will look great and hold up well.
My story is a little more complicated. I'm scar'd from an experience when I was 14. I repainted my Schwinn exactly the way I wanted it. It was great for a few days. Then the paint started chipping off in big chunks. I had just roughed up the old enamel and sprayed away. My neighbor chuckled and then showed me how to strip to bare metal, then prime then paint. That bike looked great for years. Ever since then I go to bare stock before I paint.
