JDP Motorsports
Old 08-18-2013, 03:11 PM   #1
macwest
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda
Help Please
I was driving home jumped on it slightly and now the exhaust is way louder, I am getting a misfire and a 0300 code. My traction control, stabaltrack lights on. Any idea on what sensor may have gone bad or what I may have done.
My current boost is real low 6.5 so I t was nothing extreme.
Any help would be greatly appreciated.
"Z28 = first time I bought a new car just to strip parts for my current ride. GM needs to re-think restricted parts. "
macwest is offline   Reply With Quote
Old 08-18-2013, 03:25 PM   #2
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
Check all spark plugs plus wires if you're already there...
Then move over to your cats and o2 sensors, something might have come loose there - although the latter should not give you a 0300.
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 08-18-2013, 05:05 PM   #3
blake-b
blake-b's Avatar
Drives: Black 2010
p0300 is the random misfire code. As stated, check all your spark plug wire connections. The p0300 code will cause the stabilitrack and traction control lights to illuminate.
Old 08-18-2013, 05:13 PM   #4
macwest
makes sense on the lights. Question is the exhaust sound is extremely higher but bolts and exhaust seem tight. Can a cat going out increase exhaust output , result in wrong Sensor reading that then leads to this error?
Old 08-18-2013, 05:16 PM   #5
TinyToasta
TinyToasta's Avatar
Thats what I meant with the above: check your cats. Clogged up or twisted coud lead to misfires as well (or worse...)
Old 08-18-2013, 05:51 PM   #6
macwest
Any advice on how to check cats. I have never had to check them before. From the outside they look fine.
Old 08-20-2013, 05:14 PM   #7
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
As others mentioned, a loose plug wire will cause plenty of bells & whistles to go off and light up like a Christmas tree. You'll have to pull the cats to check the inside, you won't notice damage from visual outside inspection.
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
