HeadlightArmor
Old 08-19-2013, 11:46 AM   #1
bct10985
Drives: 2010 2SS LS3, 2013 duramax
clutch for 650rwhp
My stock clutch was slipping a little on this last dyno run. I know everyone is going to say street slayer but i was hoping not to have to spend $1300. The zr1 seems to b a popular choice but is also in that price range. What about all the others ram, centerforce, spec, monster? I would like one that will work with the stock flywheel if thats possible
ECS Novi 1500 supercharger, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 10.41@133mph
bct10985 is offline   Reply With Quote
Old 08-19-2013, 11:54 AM   #2
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
Spend the extra cash...ZR1 all the way! You wont regret it!
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 08-19-2013, 12:09 PM   #3
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Mcleod RST clutch. Or even the RXT to leave room to grow. Not only did the clutch take a HUGE beating. But the customer service when calling them is great too.
you gotta pay to play.
xjer22x is offline   Reply With Quote
Old 08-19-2013, 12:18 PM   #4
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Spec stage 3+ is a nice clutch, I was going to use it before I went twin disc.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 08-19-2013, 12:32 PM   #5
Unreal
Drives: 2006 Z06
RXT. Zr1 clutch won't last long, especially if you race it.
Nick
Corvette Z06 -1200ish rwhp
Old 08-19-2013, 01:02 PM   #6
MS7
MS7's Avatar
Drives: 2011 camaro LS3 supercharger
For 650RWHP you will find many of excellent choices .
i went to Mantic ER2. check my thread below
http://www.camaro5.com/forums/showthread.php?t=267935
SLP TVS 2300,LS9 cam,ZL1 fuel bump, ADM FPCM,850ID,LT headers,CAI intake K&N, X pipe with stock exhaust Eibach 1inch suspension,Mantic Clutch 700HP, 91fule .8psi METH AEM, no timing up 557 RWHP
ZL1 black wheels,ZL1 front bumper, ground effects,
MS7 is offline   Reply With Quote
Old 08-19-2013, 01:14 PM   #7
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
I just installed a hendrix SS without the carbon pads. It was $1600 to my door and included new ARP bolts and a larger all metal throw out bearing. It had excellent instructions, and never chattered once. It's not the cheapest option, but it's a fantastic clutch.
Sent from my HTC One X using Tapatalk 4
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 08-19-2013, 06:11 PM   #8
2010SSRSM6
SoCal C5 Family Member
2010SSRSM6's Avatar
What do are you looking for the clutch to do? Do you want stock feel or does it matter?
If you don't mind a more firm pedal feel, ACT twin is good for 800hp, but it is firm and can be a PITA to setup so it doesn't chatter and get a a consistent engagement.
If you want lighter than stock pedal pressure, McCloud RXT is bitch'n. You can reuse the factory flywheel, but I'd upgrade to the steel flywheel so it will perform the best. The factory flywheel has a larger center indention that the steel flywheel from McCloud doesn't have so it gets a better mount.
The ACT runs about $850 and the RXT can run up to $1200. I'm at 620rwhp with the ACT and a buddy with the same setup has the RXT. Both hold the power, but I like the RXT much better than my ACT.
UNDER CONSTRUCTION. ETA 2016 ish...
Old 08-19-2013, 06:55 PM   #9
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Do not get the ZR1/LS9 clucth. It will easily become the worst mod you ever purchased if you do.
D1SC Procharger 881/773 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 08-19-2013, 07:01 PM   #10
CyberPredator
50 Shades of Prey
Drives: TT/SS
What he said. Don't go cheap on the clutch especially since you make power. Don't go ZR1. Mantic, Street Slayer, or McLeod. IMO. As much as it cost to swap its best to do it right
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 08-19-2013, 10:19 PM   #11
bct10985
Think the mantic sounds like the best deal
Old 08-19-2013, 10:59 PM   #12
BLACK10
BLACK10's Avatar
Mantic 9000. We have put more than 1000hp to it. Spend a little more and get a clutch that will take abuse if you choose to do so
Old 08-19-2013, 11:05 PM   #13
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
DO NOT do a ZR1 mine lasted 3 passes down the strip, it is not designed for the weight of our car at that power. I then went with a Hendrix Street Slayer Twin Carbon and haven't looked back. Great clutch and many other are running the triple at 800+rwhp and its rebuildable.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 08-20-2013, 12:55 PM   #14
H-E
Drives: 2010 zr1 Camaro 2011 vert
Thanks!
H-E is offline   Reply With Quote
