Caryle Racing
Old 08-19-2013, 07:06 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
How much HP 2.5 exhaust?
How much HP will 2.5 exhaust support in a N/A car?? Was wondering if it was worth it to go with a full 3in. system. Thanks.
Craig B is offline   Reply With Quote
Old 08-19-2013, 08:24 PM   #2
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Zero. The factory exhaust is 2.5'', and flows pretty well. There is almost no gain to be had in 2.5'' exhaust. 3'' is overkill on an N/A motor unless you have some bigger cubes, high flowing heads and a beastly cam.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 08-19-2013, 08:25 PM   #3
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
IIRC the stock system is good to ~600RWHP. Then the 3" is not just for sound anymore.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 08-19-2013, 08:27 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
You won't get a true 3" system unless you buy one. I think KOOKS and LG are about the only ones that make a full header to exhaust tip in 3".
Most headers and cat-backs have a 2.5" connection point.
Unless you're making really big HP I wouldn't worry about going to a full 3" system. However, a 3" will give you a little bit of deeper tone when idling.
Build Journal
Old 08-19-2013, 08:27 PM   #5
LS3 SS
LS3 SS's Avatar
I stand corrected OP! You're gonna need a whole LOT of cubes then lol.
Old 08-19-2013, 08:31 PM   #6
jcmG8
Drives: G8GT
the magic number is 2.2cfm /HP. Any more flow is a waste of money.
Here is a decent unbiased article with science behind exhaust system design
jcmG8 is offline   Reply With Quote
Old 08-19-2013, 08:33 PM   #7
thahemp
Geek
thahemp's Avatar
Lots of companies make a full 3".
x = ~x
Old 08-19-2013, 09:07 PM   #8
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
n/a i dont think the gains will be but like 1-2 hp if that. the weight of the extra pipe. will counter balance that tho lol
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 08-19-2013, 09:25 PM   #9
Craig B
Craig B's Avatar
Drives: 2013 1LE
Thanks for the replies. Looks like it's not worth changing to 3in.
Old 08-19-2013, 09:34 PM   #10
thahemp
Geek
thahemp's Avatar
Sure it is. A 3" sounds like heaven on these cars.
x = ~x
Old 08-19-2013, 09:52 PM   #11
Supercharged SS
Drives: 2010 Camaro
JRE has an 800 rwhp on the 2.5" exhaust. Blower car though
I run the Kooks 3". It does sound evil at the track!
Old 08-19-2013, 10:19 PM   #12
Baltimorejohn1
Baltimorejohn1's Avatar
Drives: Camaro 2SS
Great read
Baltimorejohn1 is offline   Reply With Quote
Old 08-20-2013, 11:07 AM   #13
caverman
caverman's Avatar
Not a true 3". I'm talking about 3" from the collector back.
Most 3" cat-backs have a 2.5" inlet so they can connect up to the stock mid pipes. KOOKS makes a 3" inlet cat-back as well as LG. I think ARH might have one setup that way as well.
Build Journal
Old 08-20-2013, 01:32 PM   #14
thahemp
Geek
thahemp's Avatar
And so does JBA. And so does SW. I know what you're talking about. I just know there are plenty of full 3" choices .
x = ~x
