Old 08-19-2013, 07:20 PM   #1
Emvici
Drives: 2014 ZL1 White Convertible
Post seeking advice for Dyno tuning
I am recieving my 2014 zl1 convertible around oct. 1. I have already decided to drop in a set of plustar plugs after the breakin period is over. I have never owned a Supercharged car before, and I am interested in knowing if, dyno tuning the motor will be advantageous without doing any other Modifications?.
If it is advantageous without any other Modifications done, could you please tell me what the advantageous would be and why?.
Emvici is offline   Reply With Quote
Old 08-20-2013, 03:47 PM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Congrats, As a tuner I can tell you that you should Leave the plugs alone, and put at least 1500 miles on before you tune.
Make sure you have all the bugs worked out before you start modding.
A tune can and will unleash some hidden power through reduction in torque management, we can make the car run a bit cooler, and improve your overall driving experience.
It will not be until you start turning the supercharger faster that you will see any significant gains.
May I suggest My 75 RWHP Tune Package as a first Step in your Quest for more performance.
This will put you at the same power level as the GT500.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 08-20-2013, 05:58 PM   #3
Emvici
thank you for your feedback, I will look at your website.
Old 08-20-2013, 07:51 PM   #4
babigguy
babigguy's Avatar
Drives: 2017 ZL1, 2015 Z51 vette 2005 gto
You will love the 75 hp kit!!!! I do !!
babigguy is offline   Reply With Quote
Old 09-20-2013, 10:37 PM   #5
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
... What Jannetty said, I popped all Pulstars in my Chrysler 300 to try them and experienced 0 difference and I have thousands of miles on them now. They work, but I didn't experience any HP gains and there was no change in mpg either. A waste of money in my opinion.
Turbocharged with Huron Speed & Cammed with Cam Motion from Spartan Performance, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock, Turbosmart controller, MSD 2-Step, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, CAI, Cherry Bomb, blackouts, Lowered, Custom badges, VDI lambo doors, Hines vents,RPI fender vents, BlackVue 1080P Dashcam, Technostalgia Tail Lights, KW 500W on 10", Metra Kit, Pioneer AVH 4600BT, Morimoto RGB Halos, Tuned by Pat G
SeaCompiler is online now   Reply With Quote
Old 09-21-2013, 01:41 PM   #6
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
The first thing that comes to my mind is your convertible will come with a 155 mph limiter on it. The tuner will make that go away. I agree that at a minimum if you tune the car you should have a pulley upgrade because there is a lot more power available for very little cost there. I would look for someone semi close to home (my tuner is 100 miles away) and talk to people on the board before you jump in. You will find out pretty quickly which shops back-up their work. Good Luck and welcome to ZL1 ownership!
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 09-21-2013, 08:59 PM   #7
AMMUSCLE
AMMUSCLE's Avatar
Drives: 2013 ZL1 VERT M6
Once you break it in, then you will have a better idea as to what you want.
Jannetty Racing has really nice packages that you can expand on as you go.
You do not have to put it on a dyno with every add on, just call them and they can send over the tune for your mods through an email. Makes it easy and save some serious $$$$
AMMUSCLE is offline   Reply With Quote
camaro, dyno tune, lsa, zl1
