JUICEDMOTORSPORTS
Old 08-19-2013, 08:13 PM   #1
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
Car is back and running strong
********The RPM 4L80e lvl 5 trans is working perfectly with the PCS controller. drivability is perfect. car or trans doesn't get hot, even sitting in traffic. shifts strong. its really nice not having the car constantly shifting up and down all the time.
I will have to relearn how to launch the car. on the old 6l80 with the 3200 converter. the first gear was so violent I just launched the car at idle and it would cut mid 1.5 60's. now first gear isn't nearly as violent and with the new converter I can literally foot brake the car to 3500 rpm. so I will have to spend the next couple times at the track working out what the tires will hold.
the nitrous outlet kit is also working great. I have it set up on a button and soon as I get going in first I press it and leave it on thru the pass and shifts.
I put a 3.5" pulley on the whipple. the car is really liking the extra boost, but it is not happy about the 6 rib set-up. it will DESTROY a belt in about 10 full passes. so im going to see how far I can push the 6 rib set-up then switch to a 10 rib.
the squash fuel system and lines look and function perfectly.
the same for the alky control meth system and the DSS driveshaft.
I will throw some pics up here in alittle bit.
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 08-19-2013, 08:29 PM   #2
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
what kind of power does it make now and when will you be going to the track?
9.46@146
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track
94guy is offline   Reply With Quote
Old 08-19-2013, 08:30 PM   #3
Supercharged SS
Drives: 2010 Camaro
Faster than you so go back to the track!
Old 08-19-2013, 08:44 PM   #4
94guy
i'll get back soon
9.46@146
Old 08-19-2013, 08:54 PM   #5
Rdunn
Really, Really Fast
Rdunn's Avatar
no clue, didn't dyno it, all tuning is done on the streets in real conditions. going to try and go to the track Friday night. but its been so hot lately, would pretty much be a waste of time. but I will prolly still go and work on launching the car.
Old 08-20-2013, 10:54 AM   #6
Rdunn
Really, Really Fast
Rdunn's Avatar
here are some pics
Still looks stock
meth lights
cept for the nitrous panel, still stock appearing.
not so stock looking under the hood. whipple, nitrous, meth, fuel.
im going to throw the 17" welds on here this afternoon when the baby goes to sleep. I'll try and get some pics of the driveshaft and trans.
Old 08-20-2013, 11:33 AM   #7
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Are you on the stock bottom end?
MODS:
Old 08-20-2013, 11:45 AM   #8
Rdunn
Really, Really Fast
Rdunn's Avatar
yep, 100% stock block and rotating assembly. stock heads w/ ls3 conversion
there are quite a few cars running 9's and over 900whp on the factory shortblocks.
will prolly do pistons and rods this winter.
Old 08-20-2013, 11:48 AM   #9
94guy
I would like to see what your drive shaft safety loop looks like? What rear gear are you running?
9.46@146
Old 08-20-2013, 01:40 PM   #10
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Do you have the N20 only on the button or in combination with WOT and Window switch. Cause I have seen a few on push buttons where they get all excited and after crossing the line they let out of the throttle but forget to release the button and when they get back on it kaboom.
A push button in conjunction with the other safety devices is good because you are more in control. If you start loosing traction you can release the button to gain control while still WOT.
How many lbs are you pushing with the Whipple?
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 08-20-2013, 01:41 PM   #11
Rdunn
Really, Really Fast
Rdunn's Avatar
factory rear gear.
Old 08-20-2013, 01:45 PM   #12
Rdunn
Really, Really Fast
Rdunn's Avatar
only on a button. I don't run any type of controller or window switch on any of my cars.
Old 08-20-2013, 01:48 PM   #13
post some pics when you put the Welds on
Old 08-20-2013, 02:07 PM   #14
Rdunn
Really, Really Fast
Rdunn's Avatar
I will
