JUICEDMOTORSPORTS
Old 08-20-2013, 01:14 PM   #1
unforgiven
Drives: 2011 ss
opinions wanted. biggest hp heads for supercharging that utilizes six bolt config?
opinions wanted. biggest hp heads for supercharging that utilizes six bolt configuration?
unforgiven is offline   Reply With Quote
Old 08-20-2013, 01:16 PM   #2
LOWDOWN
Downright Upright
Drives: Daily
Try here:
http://www.camaro5.com/forums/forumdisplay.php?f=74
LOWDOWN is offline   Reply With Quote
Old 08-20-2013, 03:06 PM   #3
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Originally Posted by LOWDOWN View Post
That link takes you right back to the FI Threads.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 08-20-2013, 03:42 PM   #4
Unreal
Drives: 2006 Z06
Mozez or the big All Pros.
Nick
Corvette Z06 -1200ish rwhp
Old 08-20-2013, 03:58 PM   #5
Mike@RMCR
Mike@RMCR's Avatar
Drives: Supercharged
I have had several 1100+ RWHP cars with Trickflow Heads ported by Total Engine Airflow.
Mike@RMCR is offline   Reply With Quote
Old 08-20-2013, 04:18 PM   #6
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Mast blacklabel 305 ls7 6 bolt heads here. I like em
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 08-20-2013, 04:22 PM   #7
GTPSS
Drives: 10 Camaro SS, 07 TBSS
All-Pro.
After seeing his shop, and setup first hand, there is NO OTHER!!!
07 AWD TBSS Current AWD record 768/751
10 Camaro SS Baseline 336/340
03 Silverado 1500HD 4x4 quad cab HP=lol
GTPSS is offline   Reply With Quote
Old 08-20-2013, 05:21 PM   #8
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: Camaro
I would get with Bob @ All Pro or do what i did and get with Richard @ WCCH and do the All Pro LSW-1's with his port work, mine turned out great.
BrainleSS is offline   Reply With Quote
Old 08-20-2013, 05:24 PM   #9
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
TSP ported my LSX-LS3 heads, I like em.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 08-24-2013, 02:50 PM   #10
LOWDOWN
Downright Upright
Drives: Daily
...which is where you're likely to get more (knowledgeable) responses...
Not that the few, above, aren't.
Try Billy Briggs @ Motor City Speed. 248-669-5810. They build Record Holder LSs.
Old 08-25-2013, 02:52 PM   #11
BrainleSS
BrainleSS's Avatar
Drives: Camaro
+1 Billy built my engine, he is very knowledgable!
Old 08-25-2013, 03:02 PM   #12
Camper
Banned
Drives: 10' 2SS LS3 M6
im not sure there has been a direct comparison for supercharged applications. But to name a few of what id expect to be great.
TFS GenX 255
PRC 255 or 260
Mast Black label
PRC LS7 small bore
also looks like All Pro may have 6 bolt castings.
Camper is offline   Reply With Quote
Old 08-25-2013, 03:17 PM   #13
Unreal
Drives: 2006 Z06
All pro does have 6 bolt castings.
There are $2-3k heads then there are $6-8k heads. If you want the best look at the top dollar all pro, mozez canted valve, etc.
Nick
Old 08-25-2013, 07:49 PM   #14
ayousef
ayousef's Avatar
Drives: 2013 ZL1
mozez canted valve, or even an edelbrock canted valve, then there is a WCCH ported All Pro. One of those heads have to be the best but you need a minimum bore size of 4.125" with most of those and better have a lot of air flowing through the engine or it doesn't make sense.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
