HeadlightArmor
Old 08-20-2013, 07:37 PM   #1
intensifi
Drives: '12 2LT Convertible
Partially stripped threads on Brembo calipers
In the spirit of Dustin Hoffman...
"Is it safe" or are these no longer useable???
The pictures with the red highlighting show the depth of the missing thread area.
Each caliper has one good threaded orifice. Each caliper has one "partially stripped" orifice.
Update: The Time-Sert inserts worked well. There is one snag though. The Loctite on the caliper bolts holds more strongly than the Time-Sert does. So when you reverse the bolts for removal, the Time-Sert insert loosens instead of the bolt through the insert.
This is no dig on the Time-Sert insert, they are in very tight and "seal" into the new threads as the new bolt is inserted. It's just that the GM Loctite is stronger.
Next time, I'll inspect used calipers more thoroughly.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 08-20-2013, 08:17 PM   #2
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
I'm not going out on a limb and say one way or the other, but, if they were mine, I'd drill them out completely and Heli-Coil them.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 08-20-2013, 08:59 PM   #3
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
If you need higher clamping force/torque than a Heli-Coil can handle, look into a company called Time-Sert. I'm using one in my '95 Montero to replace the threads in my crankshaft since the crank bolt broke and getting it out trashed the old threads. It will easily hold the 135 ft-lbs necessary for that application, so just saying, it can hold better.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 08-20-2013, 09:59 PM   #4
SSMickey
SECC
SSMickey's Avatar
Yea, I forgot about the Time-Sert. You should have enough material there to install them. Best place to find them would probably be a Caddy dealer as they were used to repair the old Northstar head bolt holes in the block.
Old 08-21-2013, 01:53 PM   #5
intensifi
Any idea on sizes needed for either the Heli-Coil or Time-Sert?
Old 08-21-2013, 10:06 PM   #6
SSMickey
SECC
SSMickey's Avatar
Just get them to fit the bolts you already have.
Old 08-25-2013, 10:09 PM   #7
intensifi
I'm buying the time-sert tool to rethread mine. Thanks JohnnyBFromPeoria!
I wonder if I'm rethreading one bolt hole on each front caliper, if I should just do both at the same time??? Maybe stronger that way???
Any mechanical engineers out there to answer?
Old 08-28-2013, 02:06 AM   #8
intensifi
The time-sert tool set arrived today. I must say this is one very well engineered and machined kit.
Old 08-28-2013, 04:21 PM   #9
MikeOD
Drives: 2010 M6 2SS
Use new bolts!!! The caliper bolts are torque to yield...
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 08-28-2013, 04:48 PM   #10
intensifi
I am. The time sert kit will just replace the threads in the caliper and make them much stronger.
Old 08-28-2013, 06:05 PM   #11
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
All threads have a striped appearance. But those look stripped.
Sorry. Couldn't resist.
I crack myself up!
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 08-29-2013, 05:09 PM   #12
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
If the threads in the other bolt holes are fine there's no need to re-thread them. What i would recommend you do is get a tap the same size as the original bolt holes and trace the threads on all of them to make sure you dont end up stripping out another.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
