R1 Concepts
Old 08-21-2013, 05:37 PM   #1
enyce0387
enyce0387's Avatar
Drives: 2011 camaro 2ss/rs ls3
Lifting inside rear wheel on tight turns
Having a problem putting the power down on tight turns my inside wheel has a tendency to lift and spin until either the diff locks up or I let off the gas. I have pfadt lowering springs pedders zl1 sway conversion trailing arms and toe rods gm strut bar bmr tunnel brace. Nothing to crazy suspension wise yet have a set of pedders coilovers but I didnt install them yet what do I do?
enyce0387 is offline   Reply With Quote
Old 08-21-2013, 07:28 PM   #2
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Are you sure you're lifting your inside rear tire? You'd have to be turning hard and fast to do that and the Camaro is not prone to this behaviour. I'm surprise that the tire will lift under throttle. I would have expected the rear end to step out (oversteer) before it lifts a tire.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 08-21-2013, 08:48 PM   #3
enyce0387
enyce0387's Avatar
Positive it's lifting maybe I over tightened the end links in the rear? If I do a tight circle in a parking lot at full lock and start to push it the inside wheel will spin easily. A sharp enough turn I get the same loss of traction and on an uneven surface like pulling up a apron to a driveway I'm constantly pulling a back wheel.
Old 08-21-2013, 11:35 PM   #4
Avalnch
Avalnch's Avatar
You should check that you didn't put the bar in upside down (if that is possible). If your car is lowered, you will also need shorter end links which Pedders provides.
I'm running the Pedders ZL1 spec rear bar with Pfadt coilovers (talk about a mix) and my car will oversteer when pushed too hard. Never had it lift a tire and I track + autocross my car regularly.
Old 08-22-2013, 09:01 PM   #5
enyce0387
enyce0387's Avatar
nope installed the same as all the pedders and pfadt pictures i see on here
Old 08-22-2013, 09:52 PM   #6
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
The bar being set to stiff in back can do that. Member had it happen just going uphill and in a turn at street speeds.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Pedders Supercar coilovers and Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/427 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 08-23-2013, 11:03 AM   #7
Rob@WretchedMS
Drives: His Wife Crazy
I don't think your wheel is lifting, it's just not something that is going to happen on a flat parking lot going in circles. I think you are just experiencing the diff not locking as soon as you think it should.
Rob@WretchedMS is offline   Reply With Quote
