Cold Air Inductions
Old 08-21-2013, 07:09 PM   #1
layzurguy
Ride On!!!!
layzurguy's Avatar
Drives: 2012 SS Ragtop
Remove Third Brake Lamp
Has anyone seen an easy way to remove the "High Mount Stop Lamp" from the vert?
layzurguy is offline   Reply With Quote
Old 08-21-2013, 07:45 PM   #2
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
Just curious - if you take it off, how are you going to meet the requirement to have a center brake light?
RolltideSS is offline   Reply With Quote
Old 08-21-2013, 07:52 PM   #3
layzurguy
Ride On!!!!
layzurguy's Avatar
I just want to take it off to have the lens smoked to match the tail lights
Old 08-30-2013, 08:50 PM   #4
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
Ive seen it completely removed. and molded smooth. looks great with no brake light in the center. who cares about whats legal and whats not. I see people all the time driving around with no working brake lights. do they ever get in trouble? no. when someone rearends them its not their fault either. do what you like. Ill remove mine one day when I find a set of trim pieces for cheap.
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Jer4251 is offline   Reply With Quote
Old 08-30-2013, 09:53 PM   #5
layzurguy
Ride On!!!!
layzurguy's Avatar
Just don't use the blank that they put on the 2014 vert.
NOW HOW TO I TAKE THE DARN THING OFF!!!!!!!!
Old 08-30-2013, 10:29 PM   #6
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
you want the entire thing gone, or just the lens pulled out? there are 2 screws that go into the bottom of the light to hold it in place, it slides down into the trunk compartment to come out. the actual panel its sitting in is held in place by the 2 side panels.
ill see if I can get you a pic to show you
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 08-30-2013, 10:42 PM   #7
layzurguy
Ride On!!!!
layzurguy's Avatar
Either the whole thing out or just the lens. Whichever is easier. Killed my back trying to figure it out.
Old 08-30-2013, 10:58 PM   #8
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
if u look up through the holes in the trunk where the light is, you will see 4 green tabs. you need to release the tabs and push them up. these 4 tabs hold the light housing in place. ones its out you can then unbolt the lense from the housing. its not easy unless you have a tool to fit in there.
might help to have something to pry between the housing and the body of the car, just to help keep the tabs released. just be careful.
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 08-30-2013, 11:18 PM   #9
layzurguy
Ride On!!!!
layzurguy's Avatar
Great!!! Appreciate the pics. So, do you drive the 4th gen much? I get mine out every now and then.
Old 08-30-2013, 11:25 PM   #10
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
I try but its got an issue I can't see to track down. It dies after 15/20 minutes. I've replaced just about everything it could be. Each time I think I fixed it, it leaves me on the side of the road. I'm about to give up on it. And drive my 1990 iroc vert when I'm not driving the ZL1. And my TBSS is my daily driver/ work vehicle. Rarely ever try the 97 anymore.
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 09-04-2013, 07:18 AM   #11
Mpsmith1
Drives: '13 IOM ZL1 vert
There's no such requirement. It's an added safety feature on newer cars, but the law doesn't require it.
Mpsmith1 is offline   Reply With Quote
Old 09-04-2013, 07:30 AM   #12
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Up in here in Canada land a third brake like a required on all vehicles on the highway.
Caswell239 is offline   Reply With Quote
Old 09-04-2013, 08:12 AM   #13
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
So you're saying that compliance with the Federal Motor Vehicle Saftety Standards is voluntary?
The requirement has been on the books since 1986.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 09-04-2013, 04:49 PM   #14
Mpsmith1
My bad. It not required for cars manufactured prior to 1986 (1994 for trucks). But you have to have it for cars manufactured after that date.
