Old 08-21-2013, 08:41 PM   #1
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Boost (problem)????????? Tune mabey
Have a Procharger p1sc on l99 other than that full 3 in exhaust no cat 1 7/8 Texas speed before I put on the headers I had catback exhaust making 6.2 psi at wot since the install of the headers no tune yet I dropped to about 3.2 psi is there a problem somewhere or would a tune help bring that number back up. I know I will lose some boost because I created a less restrective path for the air to travel but it just seems like more psi than I should have lost.
Trob85 is offline   Reply With Quote
Old 08-21-2013, 08:45 PM   #2
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
That's pretty much par for the course, tune won't change it. You need to pulley down to make more boost.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 08-21-2013, 08:50 PM   #3
Trob85
Svt lol
Trob85's Avatar
That's what I thought I'm not to worried right now about it since the engine is being built to run a bigger blower and more psi I was just worried there was a different problem.
Old 08-21-2013, 09:18 PM   #4
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
You should get it retuned regardless. When you add LT's it changes the tune and lets you run more lean. It needs to be compensated for before something happens. It's not likely, but better safe then sorry, it'll also bring your HP/TQ numbers up. When I had mine done and tuned, I gained 43hp at the wheels.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
