Old 08-22-2013, 08:16 AM   #1
ITMerc
Drives: A.R.D. 1500, LSX Twin Turbo
ITMerc's Twin turbo 2010
Started a new thread to document my build from when I switched to ARD and forward.
LOTS of pics to bring in and history to lay out so be patient!
Here's my mostly current build poster and a couple of pics to whet your appetite...
I'll revise this build doc/list as it evolves or I get better info:
2010 Camaro SS
Build by Owen Priest at Advanced Racing Dynamics (ARD)
Exterior:
ZL1 front end conversion
20” HRE P43 Forged Wheels with Pirelli Pzero 275 fronts, Mickey Thompson 305 'ET Street 2' rears
Weld 17" front skinny's and 15x11" rear drag wheels, 15x11.5x28" Mickey Thompson slicks
AAC LED driving lights and sidemarkers
Engine covers and led rearview mirrors by Showstopper
Custom valve covers by ARD
Custom paint by S&T Autobody
VIS Racing carbon fiber hood
Carbon by Design carbon fiber trunk
GM ground effects kit
Custom painted bowties
Blacked out tail light bezels
Interior:
Fesler 2 gauge pillar pod (suede covered)
AEM vac/boost gauge
AEM AFR gauge
Custom Suede Headliner
Custom leather seat centers
Chrome door sill plates
Drake billet pedals
5 point harness and welded in roll bar by ARD
Oracle LED interior/trunk/footwell lights
Performance/Chassis:
Custom built LSX 427 by ARD:
9.5:1 compression
Callies Magnum crank
Callies Ultra H Beam rods
Wiseco custom pistons
ARP studs
ACL bearings
Durabond cam bearings
Rollmaster billet double timing chain
Comp Cams pushrods
Custom Comp Cams cam
ARD Ported/polished 6 bolt LSX racing heads, LS7 port config
Del West titanium intake valves 2.20
Manley inconel exhaust valves 1.61
Manley .700 lift springs
Comp Cam tool steel retainers
7 Degree tool steel locks
Cometic head gaskets
ARP 2000 head studs
Com Cams trunion rockers
GM LS7 intake, Aeromotive fuel rails
OEM fuel system PLUS a 1000hp+ capable Weldon pump/regulator return system
140lb injectors
Port matched and Jet Hot coated OEM iron exhaust manifold
Painless methanol injection
Twin Precision ball bearing turbo’s 62/66mm hybrids
HKS EVC-V boost controller
Twin Tial 'Q' series blow off valves
Twin Tial 50mm wastegates
NOS 'Launcher' NO2 progressive controller
Cold FUsion 100 shot (wet) single nozzle
Cold Fusion 200shot+ direct port nitrous
Full Corsa exhaust, ceramic coated magnaflow tips
ARD custom 4l80e trans with Jakes transbrake
Custom Circle D 278mm Pro Stage 3 multi-disk converter
SFI Rated 'Raptor' flexplate
36 element super sprague
4340 billet input and output shafts
custom installed B&M Pro-ratchet shifter
Coilpack relocation kit
Baer Extreme 6S 6 piston front brakes, C5 rear brakes from ADM
Linelock
Driveshaft Shop 9” independent diff
3.89 ratio Eaton Truetrack Posi, 1350 U-Joints/Pinion Yoke
31 Spline Stubs, 31 Spline 1400 HP Axles, 1 Piece aluminum Drive-shaft
Pedders Supercar coil-overs with external reservoirs and full bushing kit
BMR Suspension:
Adjustable Front Sway Bar
Adjustable toe rods/trailing arms, solid end links
Front strut tower brace
Drive shaft safety loop
Bwoody adjustable sway bar end links
Hotchkis Suspension:
Chassis Max sub-frame and tunnel brace
Adjustable rear sway bar
Pfadt solid motor mounts and sub-frame bushings
ADM 15" rear lower control arm and C5 brake kit to accommodate a 15" wheel/slick
ITMerc is offline   Reply With Quote
Old 08-22-2013, 08:21 AM   #2
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
A sic crazy build, and two pictures is all you got?
You better get to typing and pic posting!
Old 08-22-2013, 08:21 AM   #3
SilverSlayer-SS
SoCal HT5
SilverSlayer-SS's Avatar
Drives: 2010 SS , 2014 SS
WoooooooooooW
SilverSlayer-SS is offline   Reply With Quote
Old 08-22-2013, 08:35 AM   #4
ITMerc
Here's two more... Just because you asked so nicely... (Yes, I'm enjoying this! LOL!)
Old 08-22-2013, 11:53 AM   #5
kold
kold's Avatar
Drives: 2011 LS White Camaro
pfft only 1500HP
JK brother!!!!
i dont even knw wht i would do with that much power!!!! Car looks amazing!!!! amazing build and congrats on owning that beast.
kold is offline   Reply With Quote
Old 08-22-2013, 12:09 PM   #6
PWRHSEZL1
PWRHSEZL1's Avatar
Drives: 2013 Camaro ZL1 #2419
Insane! Very nice build, how often do you actually get to use that 1500hp?
PWRHSEZL1 is offline   Reply With Quote
Old 08-22-2013, 12:48 PM   #7
SlyJester7
SoCal HT5 *COTW 8/26/13*
SlyJester7's Avatar
Drives: 2013 SS/RS LS3
Dayyum! Looks awesome!
Is that red under accents under the hood or more orange?
SlyJester7 is offline   Reply With Quote
Old 08-22-2013, 12:51 PM   #8
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
Pics do not do this car justice..
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 08-22-2013, 01:12 PM   #9
ITMerc
I drive it pretty much every weekend but realistically speaking I can only put full power down when its wearing a 15x11.5" slick on the strip. Heh!
Old 08-22-2013, 01:13 PM   #10
ITMerc
Its red, if the whitebalance is off it looks more orange in pics. Its bright red in person!
Old 08-22-2013, 01:33 PM   #11
ITMerc
Here are some pics I pulled from our club forum, I have much higher quality versions along with LOTS of other pics that I'll upload as I have time at home. There are minor differences as the car has evolved over time from these.
Corvette Chevy Expo Houston, 2012
Old 08-22-2013, 01:38 PM   #12
thebeast916
Drives: Blown G8 GT
Awesome build
thebeast916 is offline   Reply With Quote
Old 08-22-2013, 02:56 PM   #13
aquablueL99
Jackson's COTW
aquablueL99's Avatar
Drives: 1968 Camaro & 2010 Camaro 2SS
This is sooo nice....Thanks for posting all the great pix...
Congrats...
Kurt ABL99...
aquablueL99 is offline   Reply With Quote
Old 08-22-2013, 03:15 PM   #14
SilverSlayer-SS
SoCal HT5
I'd say it again, WooooooooW!
ard, bayou city muscle cars, itmerc, twin turbo
