Cold Air Inductions
Old 08-22-2013, 10:19 AM   #1
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
Anyone know the OEM part numbers?
Just looking for the OEM part numbers for the SS Brembo brake calipers for the front.
CamaroLS is offline   Reply With Quote
Old 08-22-2013, 10:26 AM   #2
Bmags
Bmags's Avatar
Drives: 2013 Camaro 2SS/RS SIM
I don't have the part numbers, but you can find them @ gmpartshouse.com or gmpartsdirect.com. Both have an online catalog. There is also a member here on this forum trying to sell his complete SS brembo brake setup. Check the FS section of this forum.
Bmags is offline   Reply With Quote
Old 08-23-2013, 08:21 AM   #3
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
92233189 Driver side front brake caliper. Without pads
92233188 Passenger side front disc brake caliper. Without pads.
92233177 Driver side rear disc brake caliper. Without pads.
92233176 Passenger side rear disc brake pad. Without pads
11570788 Front disc brake caliper bolts; to knuckle. 4 per vehicle. OPTIONAL
89047711 Front disc brake pad pin kit; 2 per vehicle.
89047728 Rear disc brake pad pin kit; 2 per vehicle.
11515781 Rear disc brake caliper bolts; to knuckle. 4 per vehicle. OPTIONAL
92227529 Driver side rear brake backing plate. OPTIONAL
92227530 Passenger side rear brake backing plate. OPTIONAL
bannonm is offline   Reply With Quote
Old 08-24-2013, 04:26 PM   #4
CamaroLS
CamaroLS's Avatar
Thank you
Old 08-24-2013, 07:11 PM   #5
CamaroLS
CamaroLS's Avatar
Do I need 16166 and 16104 they are called pin boots?
