BeckyD @ James Martin Chevy
Old 08-22-2013, 02:06 PM   #1
timtoolman24
timtoolman24's Avatar
Drives: 2012 LS3 2SS/RS
Procharger, BOV, what size spring do I need?
I have a D1 procharger, what spring do I need to get for a Tial Q??
timtoolman24 is offline   Reply With Quote
Old 08-22-2013, 02:12 PM   #2
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
You have a blowoff valve not a wastegate. Wastegate a can be used to regulate boost etc but they come with turbo kits.
You can hear my bov. Running a tial q with a -6 spring
http://youtu.be/MskFHCPPut4
http://youtu.be/_43WiRm38CU
Can't post the other videos
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 08-22-2013, 02:28 PM   #3
timtoolman24
Thanks Detoxx, I was reading a bunch of post and I confused myself, everybody says something diff ha. So my BOV stays closed until I hit my given Boost number and then it opens? At idel its closed? When I left off throttle it opens?
Old 08-22-2013, 02:38 PM   #4
Deezee
Drives: 2013 SS/RS
Here was my tial q on my c6 Vette. ECS sl1500 kit
http://youtu.be/iaLUK8Xko_E
Deezee is offline   Reply With Quote
Old 08-22-2013, 02:43 PM   #5
timtoolman24
Those both sound sick, trying to get mine to sound like that. I have whatever came on it
Old 08-22-2013, 03:02 PM   #6
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Your blow off value opens when you let off the throttle so you don't damage the blower impeller. All that boost needs to go somewhere and when the throttle blade closes it forces it back into the blower....The BOV opens to prevent this. As mentioned above the wastegate is commonly used on turbo set ups to limit the amount of boost a turbo will make. Since a blower uses pulleys you generally don't need a wastegate but it has been done before. The idea is you can use a small pulley to up your boost and make more torque down low but the safety of a wastegate to limit excess boost numbers up top.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 08-22-2013, 03:08 PM   #7
timtoolman24
Sweet thanks for quick useable info! So I need a BOV, just have to find out which size spring to get and bolt it on correct? And if I'm reading correctly, I have a Boost/vac gauge so I take what my car is at idel to get the spring correct? Vaccuum at idel. Tial q website says -2 for superchargers, -6, -8, -10, and so on do I get whats its reading on my gauge or do I get one lower?
Old 08-22-2013, 03:47 PM   #8
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
You should already have one. It comes with the kit. If you are getting a new one just see how much vacuum at idle your car pulls and get the correct spring based on that.
Old 08-23-2013, 09:34 AM   #9
stangkilr
stangkilr's Avatar
Drives: 2017 Camaro ZL1
I have an open race big red pro-charger valve. It makes one big air release noise
when you let off the gas
2017 ZL1
2014 Corvette
2002 Camaro
stangkilr is offline   Reply With Quote
Old 08-23-2013, 01:48 PM   #10
timtoolman24
Thanks
Old 08-23-2013, 03:24 PM   #11
ZuluKilla8
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
Whats the loudest one they make??
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
