sjm autoprod
Old 08-22-2013, 07:44 PM   #1
ayousef
ayousef's Avatar
Drives: 2013 ZL1
ZL1 brake weight?
Well, trying to look for the best location to save weight from without disturbing the cars balance and I think rotational and unsprung weight cannot be beat.
Does anyone have any idea how much the stock brakes weigh? including calipers, im trying to compare this to the ZR1 Carbon Ceramic brakes.
Thanks!
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 08-22-2013, 10:44 PM   #2
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 16 BMW M5 & 15 Z/28
Why not just get the Z28s CCBs?
URBAN LEGEND is offline   Reply With Quote
Old 08-23-2013, 07:21 AM   #3
orangejuice
H1 OFCR
orangejuice's Avatar
Drives: 2013 ZL1 Blue Ray Metallic
Yup
Corsa
Rotofab
BBK
ZL1 Hood/Fascia
AAC Afterburners/Sidemarkers
Havoc Black Chrome
5% Tint/20% Smoked Taillights
orangejuice is offline   Reply With Quote
Old 08-23-2013, 10:02 AM   #4
URBAN LEGEND
Should be about 40 lbs less for the CCBs. That's the difference on the M5/M6.
Old 08-23-2013, 10:05 AM   #5
THR ZL1 #1
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1
Just did rotors . . weighed them myself.
Front rotor 27 lbs.
Rear rotor 23 lbs.
THR ZL1 #1 is offline   Reply With Quote
Old 08-23-2013, 10:24 AM   #6
MPR
MPR's Avatar
Drives: 2013 Camaro ZL1
Thanks!
You'll save about 1/2 the weight for the ccb rotor which is about 10-14 lb. really depends on the size of rotor and caliper you want to use. With same size ccb rotor and upgraded brembo monoblock caliper, you should shave off about 90 lb for the four corners.
$1600 each for the rotors plus calipers. Although you may stop under 100 ft from 60-0, i'm not sure if it justifies the swap.
LSA VR38DETT 4B11 2ZZ-GE-SC N55 B18C5 302
MPR is offline   Reply With Quote
Old 08-23-2013, 06:06 PM   #7
ayousef
ayousef's Avatar
Drives: 2013 ZL1
thanks a lot for the replies guys but im trying to figure out, where are you getting all those numbers from what im trying to ask is, how can I get a damn equal sized CCB rotor for the stock brake? It does not exist...
with that said all the numbers you guys are giving out don't make any sense, there is a MOVit brake system for about $25k and if that system saves 90lbs of rotational and unsprung weight I would buy them now even thought im broke lol.
Im getting the Racingbrake upgrade and ive been told they will save 16lbs of rotational mass in total.
Z/28 parts will be available after about one year, which is a few months after the vehicle is for sale.
Lets keep the topic going.
Old 08-23-2013, 06:10 PM   #8
ayousef
ayousef's Avatar
Drives: 2013 ZL1
Front rotor 27 lbs.
Rear rotor 23 lbs.
based on Racingbrakes website their fronts are 23.5lbs and the rears are 18lbs.
if those weights are accurate the total savings will be:
17lbs which is inline with what I just said.
Old 08-23-2013, 06:45 PM   #9
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I don't know what you plan on doing with your car but I had to toss a set of front and rear "race" rotors on my CTS-V because they overheated and the Iron was full of heat cracks. I have not seen a thread on the Camaro boards of this nature but this seems to be more common in the Cadillac because of the extra weight. The brembo 2 piece rotor on the front is a great design, you may be able to save some weight but I think you will lose some dependability unless a ceramic alternative is available. Every bit of mass in the Brembo front is functional. If they could have made it lighter and reliable they would have.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 08-23-2013, 06:51 PM   #10
ayousef
ayousef's Avatar
Drives: 2013 ZL1
The reason the other rotors are lighter are because they are drilled and slotted and maybe the hats are lighter.
The reason for the bigger weight saving on the rears are because of the one vs two piece rotors.
So, show us some replacement rotors that are lighter, where are the guys that spoke about carbon ceramic replacements?
Also, I could do the ZR1 brake system however I am not sure if it will work with the ABS and other modules.
Old 08-23-2013, 07:19 PM   #11
jessrayo
Speed Freak
jessrayo's Avatar
Honestly the ZR1 brake system seems like the best option from my point of view. I'm curious how much of a difference it would make in lap times on the road course. As you may ave noticed I have a few ZR1 parts on my car and GM is very proud of all the ZR1 specific parts when it comes to pricing.
Shaving weight can be just as important as adding horses when it comes to performance but I don't think the brakes are going to give you the most bang for the buck. If you really want light you are going to have to start gutting the interior and go bare or get very light coverings, I don't know what the glass in this car weighs but I'll bet there is a lot of potential there.
Old 08-23-2013, 07:44 PM   #12
ayousef
ayousef's Avatar
Drives: 2013 ZL1
The reason I looked at the wheels/tires is because of the nature of the weight, reducing static/dead weight is good but reducing unsprung is better and rotational mass + unsprung is the best. Taking weight out of the wheels/tires or brakes is huge but again I don't know if it will work without causing any issues. I also don't know where to look to find this information, im trying not to be the guinea pig here unfortunately?
Theoretically, Brembo should know the answer to this but I don't know who and how to contact them for such an issue honestly.
Old 08-24-2013, 03:46 PM   #13
MPR
MPR's Avatar
I hope you are not talking about these rotors
http://www.racingbrake.com/Two-piece...1-F-p/2160.htm
I must agree with jessrayo with this one. I wouldn't start saving unsprung weight with another lighter iron rotors. You'll start facing with reliability issues. Unless your swapping from single to a high quality two piece slotted with aluminum hats/hardware.
You willing to spend the dough ($25K), then there is only the option of ceramic carbon brakes (ccb). I don't think anyone is offering a bolt on carbon brake kit with the zl1. So, you may have to built one for yourself or ask brembo or movit to produce one.
As for the movit
http://www.movitbrakes.com/en/media/galerie/galerie-einzelansicht/nissan-gtr-r35-ceramic-braking-system-frontrear/
Just from swapping the Iron two piece rotor on the GTR to a much larger two piece movit carbon rotors will save you 32 lb total weight. These are not the lightest carbon rotors you can get and you can save even more if you stayed with the same size front and rear.
Nissan GTR OEM Front 390x35mm (10.8 kg)
Nissan GTR OEM Rear 380x30mm (11.75 kg)
MOV'IT full Ceramic Front 400x32mm (7.7 kg only)
MOV'IT full Ceramic Rear 396x40mm (7.5 kg only)
To shave ~ 90 lb weight savings is from the stock six-piston fixed OEM Brembo front and four-piston rear calipers
with two piece iron rotor front 370mm and single piece iron rotor rear 365mm swap to something like a Brembo Monoblock GTR Caliper with latest generation Ceramic Carbon Brakes two piece aluminum hats/hardware front and rear with similar size.
Old 08-24-2013, 05:18 PM   #14
ayousef
ayousef's Avatar
Drives: 2013 ZL1
As for the movit
Rotora have a carbon ceramic brake system, 8 piston calipers upfront and 4 in the rear if im not mistaken and can produce it for the ZL1, however im not sure what the weight savings are.
I don't know if the monoblock Brembo calipers are any lighter than the two piece calipers however? Im sure they can sell you a full Brembo GTR brake system with carbon ceramic rotors, but I would do that if I had a light ass track car and not on my fully street driven ZL1.
Would be interesting if MovIt comes out with a factory replacement rotor in carbon ceramic including pads that could work nicely with the factory brake system.
