Old 08-22-2013, 09:20 PM   #1
Gen5SS
Drives: 2010 SS/RS 6 Spd Manual IOM
Shift Points
There's a lot of drag racers on this forum and I'm a novice at best. I would like to know what you guys think about shift points from the dyno sheet I have. The reason I'm asking is because my torque drops pretty quickly past 5000 rpms and by the dyno sheet it looks like I should be shifting around 6300 rpms which is 300 past peak on the dyno. As I said I'm a novice and I've looked up torque vs hp and from everything I've read it is advisable to shift 300 to 400 past peak hp. Any advice you guys have is welcome and thank you ahead of time.
2010 2SS/RS, 417 stroker, 4.0 Callies crank and rods, JRE pistons w/hellfire nitrous top rings, Kooks 1 7/8 LT, Kooks 3" Exhaust, CAI Intake and Scoop, Cam SullivanGM W/ Hardened PR, Stock Heads. Dual Springs, Mcleod RXT Clutch, Hurst LL W/ Cruise Momentary, GM 3.91 gears, Nitrous Outlet direct port 200 shot, Dedicated Fuel Cell(C16), LNC2000 and NOS Mini controller, BMR suspension w/Bushings, Pfadt Drop, Pfadt Diff Bushings, 1400hp DSS Axles, DSS driveshaft, Solid Engine Mounts, Razzi Body Kit, Speedhut Gauges,T-REX Phantom Grills (Black) 533RWHP/500RWTQ N/A, 724RWHP/816RWTQ 200 Shot
Gen5SS is offline   Reply With Quote
