JUICEDMOTORSPORTS
Old 08-23-2013, 12:03 PM   #1
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
Lance Foam Cannon, CG Mr. Pink review..
Got my Lance foam Cannon and CG Mr. Pink today from Amazon, thanks to axis I saved almost $25 on the foam cannon.....that about paid for my gallon of Mr. Pink. Thanks axis.
First thing is I power washed just using power washer without the foam cannon attached, once I power washed the entire Terrain I then attached the cannon to the wand.
I used about 4 ounces of Mr. Pink and filled the rest of the container with water, set soap mixer to max and adjusted the nozzel to a pattern I liked.
Once I had gone around the Terrain a couple of times I let it sit for a couple of minutes, I used a wash mitt to go over the entire vehicle and then again used the power washer without the foam cannon attached to remove the soap.
I have to say these two items are well worth getting, wish I would have gotten them a long time ago.....10 out 10 score for both.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 08-24-2013, 04:34 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
No pics?
[B]
Old 08-24-2013, 06:19 PM   #3
DARK AGE 53
Drives: 2010 SS
Originally Posted by CamaroDreams07 View Post
No pics?
No accuses, .......I'll try again tomorrow.
Old 08-24-2013, 07:04 PM   #4
DARK AGE 53
Drives: 2010 SS
I just went out and did a very very quick wash to give you an idea of what it looks like.
Old 08-24-2013, 07:18 PM   #5
CamaroDreams07
Drives: Slow V6
That looks fantastic. Sounds like you got a great deal
[B]
Old 08-24-2013, 10:26 PM   #6
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
I want a pressure washer so bad just to use a foam cannon . . .
ChadG is offline   Reply With Quote
Old 08-25-2013, 12:14 AM   #7
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
i tried the lance and PW but since i have well water it doenst get pumped out fast enough to supply the high powered washer i have.
NICE FOAM BTW
Old 08-25-2013, 01:04 AM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Glad you're happy with it. Now I just gotta get me a power washer.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-25-2013, 07:07 AM   #9
DARK AGE 53
Drives: 2010 SS
NICE FOAM BTW
I have well water also, the pressure is so so for the outdoor faucets. Two things to watch for, if you have a inlet filter screen on the PW pump check to see that it's not clogged, on my garden hose I have one of those shut off valves that goes on the end of the garden hose. Turn on the hose until there's a steady flow of water ( no air pockets ), turn off the valve and connect to the PW. Before I start the PW I turn on the garden hose valve and then pull the trigger on the PW hose until I have steady stream of water coming out the wand ( again with no water pockets ), once I do that I have no problems....give it a try.
Old 08-25-2013, 07:31 AM   #10
DARK AGE 53
Drives: 2010 SS
I'm very pleased with both the Lance Cannon and Mr. Pink. Again, thanks for the link.
I've had my PW now for 21 years, it has a 5HP B&S engine and a Cat Pump and still works fine. I've thought of replacing it with and electric PW but find it hard to pull the trigger, there's a ton on the market but most are a junk in my opinion.....I might feel comfortable buying this one but it's $550 http://www.northerntool.com/shop/too...0514_200350514 .
Old 08-25-2013, 11:38 AM   #11
axis
Search Ninja
axis's Avatar
I have a buddy with a fairly new John Deere that is extremely nice and forsale. I just need to justify buying it.
Halltech CF 102 fed
Old 08-25-2013, 11:48 AM   #12
CamaroDreams07
Drives: Slow V6
I have a power washer but I just don't think I'd ever bother to get it out and hook it all up every time I want to wash the car. I'm jealous of foam cannon foam, but too lazy for it.
[B]
Old 08-25-2013, 04:13 PM   #13
Fish-man
SS HWSE
Fish-man's Avatar
Drives: too many to say!
Do u use a foam gun?
I have a small gas PW.... and would love to use a cannon... just dont want to bother with getting it out everytime i want to wash a car. Considering getting a gun, but they dont look like it does near as nice a job as the cannon.
Fish-man is offline   Reply With Quote
Old 08-25-2013, 04:43 PM   #14
kostnkost
Roof expert detail noob
kostnkost's Avatar
Drives: 2013 BRM 2LT RS
+1
If I ever brought out my EPW my wife would have me power wash the house and bricks as well. So not worth bringing out of my shed!
kostnkost is offline   Reply With Quote
