Rick@Livernois
Old 08-23-2013, 09:38 PM   #1
Rickerbucks
HP addict
Drives: 2 SS RS,
After market rear control arms?
I have just come to find that the area where the stock tie rod ends on the pfadt rear sway bar attach has literally been torn away. the stock control arms are toast.
Anyone make after market control arms?
Yellow, Davenport 700, Pfadt coilovers and sway bar, Seibon CF hood, CF roof, custom CF trunk, Savini CF wheels, custom interior....you know what?....too much to list.
http://www.camaro5.com/forums/showthread.php?t=74691
Follow my 2013 One Lap Of America Blog here: https://www.facebook.com/#!/ShaunAnd...page_new_likes
2014 Jeep SRT 8 - stock
2010 Challenger SRT 8 - stock
2007 Charger SRT8 Super Bee - not stock at all.
Rickerbucks is offline   Reply With Quote
Old 08-23-2013, 09:48 PM   #2
Craig B
Craig B's Avatar
Drives: 2013 1LE
There are quite a few, BMR, Pfadt are just a few.
Craig B is offline   Reply With Quote
Old 08-23-2013, 10:07 PM   #3
grocerygetter
instigator
grocerygetter's Avatar
If you want to put a stock arm back on you can...there is a tab reinforcement out.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 08-23-2013, 10:37 PM   #4
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
So, what your saying is your rear Pfadt Sway Bar End Links ripped their mounting tab loose on the rear lower control arm....right? Yes, it happens. It's a pretty common thing. There are a couple different companies that do make reinforcement tabs to "beef-up" that mounting tab. This is an inexpensive fix and will allow you to purchase and use OEM control arms. Or, like you mentioned, you can buy aftermarket rear lower control arms. As far as I know BMR and Spohn are the only companies that make them.....BMR being FAR more popular (and for good reason).
blazzin1 is offline   Reply With Quote
Old 08-24-2013, 12:52 AM   #5
Rickerbucks
HP addict
Drives: 2 SS RS,
Thanks. Pfadt did not have any so bmr looks to be the winner
Old 08-24-2013, 09:38 AM   #6
BLACK67
Drives: 2010 Camaro 2SS/RS CGM
Send a message via MSN to BLACK67
I just put in the new GM lower control arms as I had torn out both sides on mine.
The plate thickness on the original lower arms was .120", the newer ones are .180".
50% thicker, so GM knows the weakness.
Adding the Pfadt support plates will beef it up even more.
With the new control arms you can go with the ZL sway bar latter if you want, they accept both FE3 and FE4.
Lower control arm part no. 20942237 $57.69 CDN each at my dealership.
SPi Performance Stage 3 package Comp Cam
PHADT FE4 ZL Stg.3
VMAX CNC Spiral Ported Throttle Body
Dynatech LT headers, Hi flow Cats
MBRP 3" 304 stainless X-pipe exhaust
Fastlane true CAI.
Barton shifter
BLACK67 is offline   Reply With Quote
Old 08-24-2013, 10:05 AM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
The factory arms are good, but they do leave a bit to be desired on the end link tabs. We do offer the Pfadt end link reinforcement tabs.
Part # 1410135
We also offer new GM control arms as well as BMR with free shipping! Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 08-24-2013, 10:26 AM   #8
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
Same thing happened to mine worh pfadt sport sways on my 2010. Go with the 2012 GM FE4 style LCAs, very worth it, with pfadt ZL spec sways, what a night and day differance
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 08-24-2013, 05:30 PM   #9
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
I've got the BMR Level III suspension and the Spohn LCA's. I haven't laid hands on the BMR's but the Spohn's are hefty and well constructed and they installed without issues. No complaints.
gnturboray is offline   Reply With Quote
Old 08-26-2013, 11:46 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
We build both non-adjustable and adjustable rear lower control arms for the Camaro depending on your needs. Also if you were on a tighter budget and wanted to go back with another factory lower control arm we have end link mounting braces which considerably strengthen that end link mounting plate.
BMR non-adjustable lower control arms (TCA028)
BMR adjustable lower control arms (TCA029)
BMR end link mounting braces for the factory control arms (ELK009)
T.C. Davis
tc@bmrsuspension.com
813-986-9302
