Old 08-24-2013, 03:55 AM   #1
Cooley
Cooley's Avatar
Drives: 2013 2SS 1LE
1LE Tire and Wheel Info
Rather than spend hours scanning the hundreds of pages in the 1LE forum, I thought it would be nice to have a thread where basic information about the 1LE tires and wheels could be referenced.
There is a lot of good info in the 1LE sub forum along with other sub forums on Camaro5, and I'll try to pull some of it into this thread so you don't drive yourself crazy looking for the right thread to answer your question. I'll link to other threads and to specific posts when possible.
This will be a work in progress and I welcome input!
Tire and Wheel Specs:
Tires; 285/35ZR20 front and rear. OEM is Goodyear Eagle F1
Supercar G:2 (100y) for 2013 model year. The tires are side
specific (left or right), and weigh 31 lbs per tire. Overall dia.
is 27.9" * weight and dia. info borrowed from TireRack.com*
Wheels; 10" front, 11" rear width: Offset; Front: 23mm, Rear: 43mm (stamped on the back side of the wheels)
Here's a thread on the ZL1 forums that addresses factory offsets:
http://www.camaro5.com/forums/showth...factory+offset
Cold Weather Warning for Goodyear Tires:
Our OEM tires are summer tires and are built for grip, they are not good in very heavy downpours (I know from experience), or very cold temperatures. Here is a specific post which includes a service bulletin;
http://www.camaro5.com/forums/showpo...38&postcount=5
Relearning the TPMS:
Our cars seem to fall under the "you must use a TPMS (Tire pressure monitoring system) relearn tool" category when it comes to changing tire and wheel sets around. Your experience may vary.
Here is the link to a thread which talks a bit about this and has a source for the purchase of said tool.
http://www.camaro5.com/forums/showthread.php?t=136093
Looking For a Different Size Tire?
Are you looking for a tire that will fit on your 1LE, but want to explore different sizes? Maybe you want to buy that winter set, and can't get the exact size match on those DWS's. Here's a post in this thread which contains a link with some size options and how they compare.
http://www.camaro5.com/forums/showpo...2&postcount=17
Here is a calculator I used when agonizing over my winter tire and wheel combo.. This is posted as a research tool, so I recommend you consult with your tire dealer about fitment, etc. before making that final buying decision.
http://www.tiresizecalculator.info/tires/285-35-20
Should I Use a Drive Through Car Wash?
http://www.camaro5.com/forums/showth...ght=wheel+care Look closely at posts #1 and #10
Hiding that Curb Rash on Your Brand New $1,000 Wheel
http://www.camaro5.com/forums/showthread.php?t=326671
When You Want to See How the Other Kids Do it:
A nicely done sub forum with tons of info about ZL1 tires and wheels;
ZL1 Tires/Wheels http://www.camaro5.com/forums/forumdisplay.php?f=156
More to come
Cooley is offline   Reply With Quote
Old 08-24-2013, 05:40 AM   #2
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
Great info Mr. Cooley!
Southern Comfort is offline   Reply With Quote
Old 08-24-2013, 06:32 AM   #3
canecorso69
run ur car not ur mouth
canecorso69's Avatar
Drives: 2013 1LE
Thanks for this. Its gonna be helpful for sure.
TSP headers, cat delete, x-pipe, atak, RPM custom cam and tune, Phfadt 1.25 springs, 15" Carlyle conversion, Nitrous Outlet
canecorso69 is offline   Reply With Quote
Old 08-30-2013, 09:30 PM   #4
redcbs
redcbs's Avatar
Drives: 2014 AGM 2SS/RS 1LE
The stock tires are 285/35zr20's, and my experience (and knowledge) is in off-road tire fitment. That said, with the wide wheels in the back, has anyone tried to run 285/30zr20's? Will the extra inch of wheel width and loss of 14mils of sidewall pull the bead off the wheel or put the sidewall at too severe of an angle? I can get brand new ps2's for $130/tire so I think it's worth asking the question... search didn't come up with anything useful.
Sent from my SAMSUNG-SGH-I537 using Tapatalk 4
2014 AGM 2SS 1LE RS - On Order 8/23/13, TPW 9/9/13, Built 9/12/13, Shipped 9/17/13, At dealer 9/29/13, Received 10/4/13
2011 V6 DC 4x4 AT Tacoma
1985 NA MT 300zx
redcbs is offline   Reply With Quote
Old 09-01-2013, 03:47 PM   #5
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Here are all the choices for the 285/35/20 size. There a couple of new offerings. I have a little over 10k on mine and am ready for some new rears for sure!
tramtwo is offline   Reply With Quote
Old 09-01-2013, 04:45 PM   #6
flyinlow
flyinlow's Avatar
Drives: 2017 Camaro ZL1
I narrowed down the selection, took out all the speed rated tires less than 149mph.
http://www.tirerack.com/tires/TireSe...35&diameter=20
flyinlow is offline   Reply With Quote
Old 09-02-2013, 07:52 PM   #7
camaro2lt
camaro2lt's Avatar
Did you guys know that the 1le wheels are specific to each corner of the car meaning that u can not fit a rear 1le wheel on the front.....the wheels are different part#s but the tire is the same size....just figured this out
Old 09-02-2013, 08:17 PM   #8
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
There is a right and a left for the tires.... don't think there is also front and back. Can you give more of the info you found? Part numbers? The wheels are different sizes 10in up front and 11in out back.
Old 09-02-2013, 08:24 PM   #9
camaro2lt
camaro2lt's Avatar
Mine are 20X11 in the rears with 285 goodyear tires...and 20x10 in the front
part#s are 22798740 and 22798741
40 is in the front
Old 09-03-2013, 10:11 AM   #10
flyinlow
flyinlow's Avatar
Correct, wheels are 20x10 for the front and 20x11 for the rear, same as the ZL1. Only difference is the ZL1 runs a larger tire in the rear, with the 1LE they stayed with the same size tire as the front to eliminate the understeer.
Old 09-03-2013, 12:34 PM   #11
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Originally Posted by camaro2lt View Post
Did you guys know that the 1le wheels are specific to each END of the car meaning that u can not fit a rear 1le wheel on the front.....the wheels are different part#s but the tire is the same size....just figured this out
Corrected it for you. Corner would indicated ther eis a left side and right side wheel which is not correct. There are only front wheels and rear wheels.
Originally Posted by flyinlow View Post
Correct, wheels are 20x10 for the front and 20x11 for the rear, same as the ZL1. Only difference is the ZL1 runs a larger tire in the rear, with the 1LE they stayed with the same size tire as the front to GREATLY REDUCE the understeer.
Because I was at it.....updated that one too! From experience it is not fully eliminated.
-Matt
Old 09-03-2013, 12:44 PM   #12
krazzyk01
Liv'n The Dream!
krazzyk01's Avatar
Drives: 2013 Black SS RS 1LE
Has anyone looked into optional size limitations? Not sure if changing things like this would be all that wise but it would be interesting to see if there's a more common sized tire out there which is cheaper/more available than the standard size. Just a thought.
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
krazzyk01 is offline   Reply With Quote
Old 09-03-2013, 04:58 PM   #13
redcbs
redcbs's Avatar
I also would like to know if people are running alternative sizes (see post 4)
Sent from my Galaxy S4 Active using Tapatalk 4
1985 NA MT 300zx
Old 09-03-2013, 06:46 PM   #14
willc1980
Drives: 2013 Camaro SS 1LE
i didnt think that $250 a tire for the OEM was that bad...
willc1980 is offline   Reply With Quote
