Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 08-25-2013, 04:50 PM   #1
Virus's Avatar
Drives: 2011 Camaro SS
Accusump with R-comp
Just recently got Hoosier R6's and I'm going to use them for the first time, at lime rock coming up. I'm a bit nervous about all these engine oil starvation stories. Should I buy an accusump? I have also read that accusumps aren't worth the time? Any insight would be appreciated.
Sent from my iPhone using Tapatalk - now Free
Virus is offline   Reply With Quote
Old 08-26-2013, 01:23 PM   #2
Drives: not stock
I would go to the corvette forums, a lot more people dealing with this issue there with the LS3. If you go to a track that has the sustained high g turns with r comps you will probably get into trouble. It may not be right away and a lot of tracks you'll probably be fine, but it only takes 1.
To me an accusump is a bandaid and I agree there's a lot of mixed reviews on reaction time and usefulness in the event of starvation. There's many levels of dry sump systems. From stock vette setups to full on race. If you're going to do it I'd get a real race setup but I could only find systems that made you sacrifice your a/c. Heck no. Crank driven setups would need a LS7 crank or some run adapters on ATI's.
Old 08-26-2013, 07:42 PM   #3
Drives: SS
This is all you need.
The 5th gen pans are large enough to work very well with a proper baffle on real tires.
toNspahreP is offline   Reply With Quote
