Old 08-26-2013, 04:57 PM   #1
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Why is passenger low-beam brighter?
I'm installing new bulbs and my passenger bulb is significantly brighter. Originally, my stock passenger bulb was brighter, and I thought the headlights needed replacement anyway, but here is a brighter replacement bulb.
The first pic is this morning with stock bulbs.
The second pic is right now with Sylvania XtraVision replacement bulbs.
Help!
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 08-26-2013, 05:32 PM   #2
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
Bad ground on the LH (driver's) headlight. Check the connector first, then work your way back.
OR
Are you getting proper intensity change high beam vs low beam? Could be some resistance in the circuit.
Bye bye, Bumblebee!
Old 08-26-2013, 05:34 PM   #3
The_Blur
Jayhawk USN
The_Blur's Avatar
I'm pretty mediocre with wiring. If it's a bad ground, what do I do?
TO: Camaro5//
warn 145:154 ban
Old 08-26-2013, 05:35 PM   #4
Diode Dynamics
Diode Dynamics's Avatar
Drives: Camaro Lighting Experts
Did you replace one of the bulbs at a different time?
As a rule of thumb you should always replace bulbs at the same time, otherwise one side ends up brighter than the other.
Nick C.
Diode Dynamics is offline   Reply With Quote
Old 08-26-2013, 05:39 PM   #5
strych9
Gone Euro!
strych9's Avatar
Most ground problems originate at the connector terminal. With the lights on, kind of pull the connector partially backwards and then reseat it. If the intensity changes at all, get a replacement connector pigtail from your local parts joint, cut off the old and crimp on the new.
If it doesn't change, make a temp ground wire straight to a known good ground nearby under the hood, and back probe the connector on the ground pin while the light is on. See if it changes then. If so, make a new ground location for a permanent fix, and use a new pigtail when you do it.
Bye bye, Bumblebee!
Old 08-26-2013, 05:44 PM   #6
The_Blur
Jayhawk USN
The_Blur's Avatar
It appears to stay the same brightness when partially inserted, so it must be damaged elsewhere. I don't have the equipment to do the rest of the steps, so I'm going to need a buddy in Pensacola. I'll provide the beer.
TO: Camaro5//
warn 145:154 ban
Old 08-26-2013, 05:46 PM   #7
The_Blur
Jayhawk USN
The_Blur's Avatar
Nick C.
I'm replacing both as we speak. I know better than to mismatch my bulbs, but I appreciate the help troubleshooting.
TO: Camaro5//
warn 145:154 ban
Old 08-26-2013, 05:53 PM   #8
strych9
Gone Euro!
strych9's Avatar
Happy to assist you if you fly me in!
Bye bye, Bumblebee!
Old 08-26-2013, 05:54 PM   #9
The_Blur
Jayhawk USN
The_Blur's Avatar
I'm a little early in flight training to give you a lift.
TO: Camaro5//
warn 145:154 ban
Old 08-26-2013, 06:04 PM   #10
Diode Dynamics
Nick C.
Old 08-26-2013, 06:28 PM   #11
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
Is it possible that one light is aiming up an the other straight or down?
45thCamaro is offline   Reply With Quote
Old 08-26-2013, 06:58 PM   #12
The_Blur
Jayhawk USN
The_Blur's Avatar
That's a good thought, but adjustment does not help. I damn-near blinded myself getting in from of both bulbs, but one is definitely more blinding than the other.
TO: Camaro5//
warn 145:154 ban
