R1 Concepts
Old 08-26-2013, 05:12 PM   #1
65special
65special's Avatar
Drives: still looking
1/4 back set up
1/4 Miles Drag Racing
I don't want to break the bank, I want to spend my money wisely, so here goes .. this is my set up;
supercharged v3 vortech with a 6.5lbs pullley with a fresh tune (dyno 493torque/ 520hp at the rear wheel), slp long tube, high flow cats, flomaster to the back, the rest is stock and looking to build the back end up, then maybe front runners buts that's for later.
"test and tune" at the track time on stock perrelis at 33lbs (small burn out) was 12:17 at 118/ 60' was 1.9, if i go down one more pulley size down, maybe go to 560 torque/ 580 hp???
all I would like is to run an 11:50et all day, consistency is my game driveshaft/control armes/ shocks/gears/frame mounts and so on .
some of you guys have been there and have made all the mistake I want to skip so thank you for your help!
Steven
updates! i have the line locked installed and i'm now running 275/40/20 nitto drag radials, not yet track tested 11:80's?
65special is offline   Reply With Quote
Old 08-26-2013, 05:43 PM   #2
65special
65special's Avatar
sorry for all the stupid questions but my last car war a 1972 camaro 421ci dart auto, 373 gears that ran 10:90's all day long...
old school!
Old 08-26-2013, 06:25 PM   #3
Supercharged SS
Drives: 2010 Camaro
18" corvette replicas with 18" drag radials. They will work great with low rwhp cars and will fit your budget.
Old 08-26-2013, 07:13 PM   #4
65special
65special's Avatar
thank you
Old 08-29-2013, 09:45 PM   #5
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
They can be had for $150 each. Make sure you get the 40 MM offset.
Old 08-29-2013, 09:47 PM   #6
Supercharged SS
Drives: 2010 Camaro
That's cheap!!
18x9.5, 40 mm
Bolt right up with the stock lugs. Just zip tie the e brake cable back.
Old 08-31-2013, 08:06 AM   #7
65special
65special's Avatar
thank you
Old 08-31-2013, 01:03 PM   #8
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
I am using 18x10.5s vette wheels with a very thin spacer.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 08-31-2013, 06:25 PM   #9
65special
65special's Avatar
Well its all about testing and tuning I guess, so I took it to the track last night, was hooping to break the 12's but no go...
put in 3 runs and called it a night, running Nitto's 555 275/40/20 at 24lbs (next time 18 to 20) and a 3/4 tank of gas did not help at all! LOL
slow and steady, step by step, it's all good
[IMG][/IMG]
