Old 08-26-2013, 08:07 PM   #1
AJT31
AJT31's Avatar
Drives: 2013 2ls
Just intalled my ebay cold air intake
I bought a cold air intake from ebay for $120, The ebay user rating was very high so i figured id go with it. The installation was pretty easy only took me a little over an hour. It works great i can definitely hear the difference and feel it a little more on take off. What do you guys think should have i gotten a better brand like vararam or k&n? Would the gains have been a lot better?
Over all i'm very happy with it for the price, and would recommend.
AJT31 is offline   Reply With Quote
Old 08-26-2013, 08:21 PM   #2
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
Nah there really is no gain performance wise from any cold air intake. Just looks. Maybe 2 or 3 hp but nothing significant.
45thAnniversary2SS is offline   Reply With Quote
Old 08-26-2013, 08:29 PM   #3
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
Care to elaborate on how you figure this? The dyno testing from JRE indicates otherwise.
RolltideSS is offline   Reply With Quote
Old 08-26-2013, 08:29 PM   #4
White Shark
White Shark's Avatar
Drives: 2013 SS LS3
Now you need to add a mass airflow sensor and American Thunder Flowmasters to complete your Mod. Once you open up the front end, you might as well open up the back end. And yes, I also did notice a big difference in performance on my 2011 LS.
White Shark is offline   Reply With Quote
Old 08-26-2013, 08:30 PM   #5
RolltideSS
RolltideSS's Avatar
It doesn't look like your heat shield is insulated so you might increase the effectiveness by adding that. You'll also get more if you do the washer bottle delete and scoop install. Doesn't take long and it is worth it
Old 08-26-2013, 08:36 PM   #6
AJT31
AJT31's Avatar
Drives: 2013 2ls
Thanks i'll take that into consideration, do i have to remove the bumper in order to remove the washer bottle?
Old 08-26-2013, 08:37 PM   #7
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
looks like k and n intake with different tubing
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 08-26-2013, 08:40 PM   #8
AJT31
AJT31's Avatar
Drives: 2013 2ls
Originally Posted by White Shark View Post
Now you need to add a mass airflow sensor and American Thunder Flowmasters to complete your Mod. Once you open up the front end, you might as well open up the back end. And yes, I also did notice a big difference in preformance on my 2011 LS.
Thanks, Where can i find a good air sensor.
Old 08-26-2013, 08:42 PM   #9
White Shark
Drives: 2013 SS LS3
There is a relocation kit, but bought my '13 SS before I could get it done.
Old 08-26-2013, 08:44 PM   #10
RolltideSS
RolltideSS's Avatar
Nope - I removed the bottle and installed the adm scoop without even removing the front wheel or fully removing the wheel well liner. It definitely isn't the easiest way but there is room to get it done if you don't have a jack or stands
Old 08-26-2013, 08:47 PM   #11
White Shark
Drives: 2013 SS LS3
Made by Jet Performance!
Old 08-26-2013, 08:48 PM   #12
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
To me all intakes are the same, as long as you have a good heat shield and the MAF location is correct you'll be fine.
Mvp_Me is offline   Reply With Quote
Old 08-26-2013, 08:57 PM   #13
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Before you buy a Jet MAF, do a search on the forum to find out its true value.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 08-26-2013, 09:16 PM   #14
montreal2010yellow
montreal2010yellow's Avatar
I wonder
I've installed 2 K&N CAI when I started to go that route and I got a CEL both times.
Than I decided to go to the open air filter route like I see on many many Stangs that don't have a heat shield.
I installed a G5CR CAI over 2 years ago and man I felt the difference. I runned my car with a ACS Nickey Chicago Hood with a ram air to the filter for 2 yeas and I recently changed it to an ACS TL1 Hood with lots of hot air coming out and fresh air coming in . I never regretted going with the open filter and I'm not a fan of closed in-a-box CAI which I beleive are not getting enough fresh air drom the grill.
I'm getting the car dynoed in the next weeks than I'll get the exact figures on HP and Tork gains
Name:  engine bay 08 07 13.jpg
Name:  TL1 full side.jpg
