Flowmaster Exhaust
Old 08-27-2013, 12:29 PM   #1
Twin2010
Drives: 2010 twin turbo ss
What compression ratio is everyone running on built boosted motors?
Built for pump gas
Twin2010 is offline   Reply With Quote
Old 08-27-2013, 12:48 PM   #2
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
After i am done with my build. i will be right around 9.7:1 CR.
Yes the more you lower CR, the safer you are running more boost. But that also has the reverse affect that the car looses power when not in boost. So race application you can go lower, but being a street car that i most likely will DD. Its good to have slightly higher compression.
When i am done i will be running around 14-16psi on the street and 18-20psi @ the track. Should be fun to say the least.
xjer22x is offline   Reply With Quote
Old 08-27-2013, 01:15 PM   #3
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
9:1 here, but my motor is purpose built for racing, not a street driver at all.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 08-27-2013, 01:28 PM   #4
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Im at about 9.4:1 with -23cc Wiseco coated blower pistons. At least the CR i calculated to to be with 70cc chambers. I run Torco Accelerator blended with 93 octane for an in tank octane of about 95-96 octane plus the meth during summer. Car was tuned with meth turned off.
Im only 14psi now on my little D1SC but am about to pull the trigger on twin PTE6766 turbos running up the boost to 18 or so and a little over 1000rwhp.
Just a street car that was built to run down ZO6s and ZR1s on the road course a couple times a year
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 08-27-2013, 02:05 PM   #5
Unreal
Drives: 2006 Z06
9.7:1 but if I could go back I would do 10:1.
Nick
Corvette Z06 -1200ish rwhp
Old 08-27-2013, 04:33 PM   #6
old motorhead
Drives: Maggie blown LS3 vette
How much boost are you going to run? What octane fuel? Using meth?
old motorhead is offline   Reply With Quote
Old 08-27-2013, 04:56 PM   #7
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
9:1 only at 12lb of boost will go for 18lb soon
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 08-27-2013, 05:09 PM   #8
blake-b
blake-b's Avatar
Drives: Black 2010
10.2:1 If I recall...
93 octane and meth, 22#
Old 08-27-2013, 05:26 PM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
9.7:1 for pump gas at 12 lbs on the street with 97 octane... With 429 CI, this is good for right at 900 RWHP
Racing we bump the boost to 25 lbs and run C16 race fuel... in the tank and to mix with the nitrous...With the 429 CI, this makes for a hell of a lot more power....
If everything seems under control, you're just not going fast enough. Mario Andretti
Old 08-27-2013, 05:38 PM   #10
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
10.4:1 on 93 octane and meth
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 08-27-2013, 05:55 PM   #11
simon.w
Drives: 2011 2SS RS 6M Inferno Orange
10.1:1 ... Which was recommended by Dustin Whipple to get the best efficiency out of the blower.
simon.w is offline   Reply With Quote
Old 08-27-2013, 07:34 PM   #12
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I will be at 9.5:1 per Andy at ADM running around 13-15psi.
MODS:
Old 08-27-2013, 07:36 PM   #13
Detoxx03
ЯєŧąяĐ Єlmиąŧя
Detoxx03's Avatar
Drives: 2008 Corvette
Between 9.8-10.2 is the best place to be.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 08-27-2013, 07:54 PM   #14
jamesr
jamesr's Avatar
Drives: 2012 Camaro ss
10/7 on my build waiting on heads to get done with the porting
jamesr is offline   Reply With Quote
