Old 08-27-2013, 08:22 PM   #15
Camper
Banned
Drives: 10' 2SS LS3 M6
o man, am i gonna be the winner here?
10.7:1
E85+meth
Camper is offline   Reply With Quote
Old 08-28-2013, 02:11 PM   #16
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
10.3 - 15psi - pump gas (93+)
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 08-28-2013, 03:49 PM   #17
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
9.9 to 1 here. 12 lbs on pump gas
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 08-28-2013, 06:16 PM   #18
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Man that's a lot of torque!!
MODS:
Old 08-28-2013, 11:03 PM   #19
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
9.7:1 on 91, 11lbs through twins.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 08-28-2013, 11:08 PM   #20
ddck24
ddck24's Avatar
Drives: 2012 Camaro 2ss 45th M6
10.6:1 on 16 lbs peak on meth and pump gas
ddck24 is offline   Reply With Quote
Old 08-29-2013, 01:19 AM   #21
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
10.1:1
Unavowed is offline   Reply With Quote
Old 08-29-2013, 01:36 AM   #22
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
It was recommended that I go with a 10:1 minimum with meth for a street/track car. Motors not built yet but it's next on the list.
K32 Camaro is offline   Reply With Quote
Old 08-29-2013, 02:51 AM   #23
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
10.0:1 running 91 octane with 9.5 psi, 95 octane 10.5psi & 98 octane 12.5psi, 3 pulleys for all occasions.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 08-29-2013, 08:57 AM   #24
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
I'm going to run a 9:3 compression but I'm going to be in the higher hp numbers so I will be relying on boost for most of the power.
Trob85 is offline   Reply With Quote
Old 08-29-2013, 12:11 PM   #25
H-E
Drives: 2010 zr1 Camaro 2011 vert
11-1 for me and I run a Maggie....With our record holding GTO street car were at 10.4-1 runs 8.70s at 4000lbs... It uses a F1R at 24lbs and runs 93 0n the street...The old school guys like low cr,back when we used carbs it was a must but with todays pcm and fuel injection and a good tuner CR is your friend...That's my opion and its worked great for us,im actually nugeing at Farrad to up the CR on there record holding 5th gen ...
H-E is offline   Reply With Quote
Old 08-29-2013, 07:11 PM   #26
ayousef
ayousef's Avatar
Drives: 2013 ZL1
9.7:1 for pump gas at 12 lbs on the street with 97 octane... With 429 CI, this is good for right at 900 RWHP
Racing we bump the boost to 25 lbs and run C16 race fuel... in the tank and to mix with the nitrous...With the 429 CI, this makes for a hell of a lot more power....
Unless you have HUGEEE turbos I think your 12psi 900rwhp estimate might be a little too optimistic?
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 08-29-2013, 07:30 PM   #27
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
He does have huge turbos, everything about his car is insane.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 08-29-2013, 07:48 PM   #28
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
And its not an estimate. Its proven. Check out his build thread.
sent from my galaxy s3. that would explain the errors.
xjer22x is offline   Reply With Quote
