BeckyD @ James Martin Chevy
Old 08-27-2013, 03:37 PM   #1
dlluinstra
David
dlluinstra's Avatar
Drives: 2010 LT2 RS Red Jewel Tint
V6 to SS brake conversion question
Is it worth keeping the front calpier weights? I am planning use plenty of brake lube as recommened in another thread.
If not needed I would remove them before painting.
Great information through out this forum.
Thank you
David
dlluinstra is offline   Reply With Quote
Old 08-27-2013, 05:26 PM   #2
intensifi
Drives: '12 2LT Convertible
Are you talking about the weights on the (early) calipers themselves or the "roller skate" weights on the Brembo brake pads?
If it's the pad weights then you might as well keep them until you replace the pads.
I heard the 2010 calipers had weights that haven't been used on subsequent models.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 08-27-2013, 07:04 PM   #3
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
I purchased some used...they had tire weights on them...i removed them and installed with regular pads with no weights...i honestly havent felt any side effects...
13blackLS is offline   Reply With Quote
Old 08-27-2013, 08:49 PM   #4
dlluinstra
David
dlluinstra's Avatar
thank you
i wiil remove them.
certainly will look better
thanks
David
