BORLA
Old 08-27-2013, 08:48 PM   #1
Big C CamaroSS
Drives: Black Camaro 2SS/RS 1LE
Opinions....Baer Decela-rotors good quality?
I'm looking for rotors that look "nicer" than the stock SS rotors. I have no interest in tracking my camaro and I have no interest in dropping $1700-$1850 on Racing Brake rotors. I think Baer (and Brembo) are a good quality second tier rotor (with Racing Brake being numero uno!), I'd just like to hear some opinions.
Big C CamaroSS is offline   Reply With Quote
Old 08-28-2013, 10:36 AM   #2
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
We have a good line of our Stillen Sport Rotors available.
You have your choice of Cross Drilled, Slotted, Cross Drilled/Slotted and Hook Slotted!
http://www.camaro5.com/forums/showthread.php?t=257770
Purchase any of our Rotors and receive FREE Stillen Metal Matrix Pads!!
PM or Call me directly with any questions!
Team STILLEN is offline   Reply With Quote
Old 08-28-2013, 10:42 AM   #3
Denis
Denis's Avatar
Drives: 2010 SS
im running the Baer rotors and i like em alot. the only thing ive noticed is that i get more brake squeel once i put them on...not sure why.
Old 08-28-2013, 02:42 PM   #4
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
What pad are you running? Stock? If you just added the rotors, you need to sand/scuff the used pads, and Lube the slides and hardware.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 08-28-2013, 07:32 PM   #5
Denis
Denis's Avatar
Drives: 2010 SS
Yea stock pads. I need to rip em apart and lube everything.
Old 08-28-2013, 07:36 PM   #6
SPCBA
Drives: pleather and Chiclets
Isnt those particular rotors from Baer heavier than oem?
SPCBA is offline   Reply With Quote
Old 08-29-2013, 04:10 AM   #7
jonathanmoguel
MM.CC
jonathanmoguel's Avatar
Drives: 2010 Camaro 2SS LS3
i have those baer rotors too
they work great with stainless steel lines
2010 camaro ss: Volant cold air intake, BBK Shorty Headers, JBA offroad midpipes, Diablosport tuned (custom tune), SLP II loudmouth axleback, ZL1 Short shifter, nitrous outlet wet "100 shot"
jonathanmoguel is offline   Reply With Quote
Old 08-29-2013, 05:07 AM   #8
Big C CamaroSS
Nice....thanks everyone. I have Pedders stainless steel brake lines so that should be a good combo.
Old 08-29-2013, 06:45 AM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
SS lines will make anyones car brake better. They won't bulge at all when you apply pressure. That means all the fluid pressure is transmitted directly to the brake piston. It sounds like the OP is just wanting to add the cross drilled rotors for the look, not necessarily for any braking performance. SS lines would be nice if he's willing to drop another $200 for some actual performance.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-03-2013, 04:17 PM   #10
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
We carry them and are very happy with the quality. We offer an upgrade package as well, the Baer rotors, Hawk pads and S/S brake lines. Great feedback from all the clients that have gone that route.
Baer also warranty's them against warping or cracking for 3 years as long as they are not worn below minimum thickness.
Piccione Performance is offline   Reply With Quote
