Old 08-28-2013, 02:21 PM   #1
mrpyle
mrpyle's Avatar
Drives: 2011 2LT/RS - Synergy Green
Lowering spring choices 2LT - input?
Of all the brands available ... I have some questions.
Some kit's come 1" front and 1" rear. Some are offset 1" front 1.3" rear. And then there are others from 1"-1.4" ... I'd like to see the difference in the rear visually before ordering.
Can someone post pics of their LT V6 drop 1" front and back ... and then someone with 1" front and 1.3" back? I know it's not quite 1/2 an inch difference, but would like to see before ordering. If you have before and after pics, that would be cool too.
Mainly cosmetic appearance for me, I don't plan to do any kind of tracking.
mrpyle is offline   Reply With Quote
Old 08-28-2013, 03:04 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Our BMR V6 Camaro specific lowering springs (SP052) lower the car 1.2" all the way around. We chose this drop height to give the cars a nice aggressive stance without putting too much extra strain on the factory strut/shocks. Here are a couple cars equipped with the BMR V6 Camaro specific lowering springs (SP052).
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 08-28-2013, 05:25 PM   #3
mrpyle
mrpyle's Avatar
Exactly what I was looking to see ... thanks Kyle.
Old 08-28-2013, 08:33 PM   #4
mrpyle
mrpyle's Avatar
Finally found a thread with all the info I need :P
http://www.camaro5.com/forums/showthread.php?t=264325
Old 08-28-2013, 09:44 PM   #5
richard200593
richard200593's Avatar
Drives: 2012 45th Anniversary RS
BMR 1" front 1.4" rear
Edit***
It's a 1 inch drop in the rear and 1.4 inch drop up front, had it backwards.
*Performance:
mrt v2.0 exhaust/CAI Intake
*Cosmetic:
Zl1 factory Reproduction wheels
Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights
*Audio:
Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box
richard200593 is offline   Reply With Quote
Old 08-28-2013, 11:43 PM   #6
Erk
Drives: Convertible
Will the BMR Lowering springs also fit on the Convertible V6? I have a V6 Convertible 2LT.
Erk is offline   Reply With Quote
Old 08-29-2013, 07:23 AM   #7
mrpyle
mrpyle's Avatar
See, i can't tell a difference in the rear with 1.4" ... looks the same to me. Then again, we are only talking about a small difference I guess. Wonder if there is any noticeable ride or handling differences in a 1" rear and 1.4" rear drop.
Old 08-29-2013, 10:30 AM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Glad I could help you out, if you have any questions let me know.
Our BMR V6 specific lowering springs will work for the convertible V6 Camaros just fine. With the convertible cars our springs will lower it slightly lower than the advertised 1.2" drop because of the extra little bit of added weight versus the coupes.
See, it can't tell a difference in the rear with 1.4" ... looks the same to me. Then again, we are only talking about a small difference I guess. Wonder if there is any noticeable ride or handling differences in a 1" rear and 1.4" rear drop.
With the V6 Camaros you really need to use the V6 springs on the rear of the car at a minimum because the rear shock on the V6 cars have a different stroke length than the V8 cars which is why people were having issues with the spring popping off the rear shock mounts. For the front you can use any of 2010+ Camaro lowering springs and they will work just fine. What I would really recommend is just sticking our full BMR V6 specific lowering springs because they are designed specifically with the V6 cars in mind.
T.C. Davis
813-986-9302
Old 08-29-2013, 10:37 AM   #9
j0s394
j0s394's Avatar
Drives: 2012 Camaro 2Lt RS Ashen Gray
Here is my 2012 2lt with the BMR Lowering Springs 1.4" in the front and 1" in the back.
scared of heights
j0s394 is offline   Reply With Quote
Old 08-29-2013, 10:39 AM   #10
j0s394
j0s394's Avatar
scared of heights
Old 09-03-2013, 12:27 PM   #11
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
We don't recommend going lower than 1", if you want lower use coilovers. The factory shocks and struts have a recommended operating range, if you go more than an inch, they start getting real close to riding out of there range, throw in passengers or any weight in the trunk and it definetly takes it out of the normal operating range which will lead to premature shock and strut failure. We have seen quite of few leaking rear shocks on lowered Camaro's, most with lowering springs that are more than an inch.
We recommend the Hotchkis 1" springs when lowering, they have the best ride as they are a progressive rate spring and are tuned for comfort under normal driving conditions and they firm up as you start to push the car.
Piccione Performance is offline   Reply With Quote
Old 09-03-2013, 12:38 PM   #12
BMR Sales
BMR Sales's Avatar
Drives: Race Car
When you get your BMR springs installed make sure you post up some pictures of your car with its new stance!
T.C. Davis
813-986-9302
Old 09-03-2013, 01:57 PM   #13
mrpyle
mrpyle's Avatar
They arrived today ... waiting for my new wheels to come in, then taking the car down to get it all done. Will post pics when complete. Prob be around the 16th, my next weekday off.
Old 09-04-2013, 08:01 AM   #14
BMR Sales
BMR Sales's Avatar
Drives: Race Car
That would be awesome!
Well if there is anything else I can help you out with let me know.
T.C. Davis
813-986-9302
