Gen5DIY
Old 08-29-2013, 04:23 PM   #1
Camaro2ss2013
Camaro2ss2013's Avatar
Drives: 2013 2SS Camaro
Tire Spin
I haven't been able to get my car (2013 2SS NPP M6) to break the tires loose at a 10 mph roll yet. I have floored it many times with the stability and traction control off and maybe get a little squeal out of them. Not that I'm complaining because she just squats and hauls. I would think 426 hp should light the tires up at a 10 mph roll if wanted. I only have 1269 miles on the car and a CAI intake on it other wise it is completely stock. Fuse pull was done the day after purchase and she only gets Premium fuel (93). I have an appointment to get the car put on the dyno next Friday to see if its putting the HP down that it should. Has anyone else on here had this happen?
Camaro2ss2013 is offline   Reply With Quote
Old 08-29-2013, 04:29 PM   #2
Cookie Monster
Belle Isle
Cookie Monster's Avatar
Drives: 2014 1LE
2014 2SS
Credit to xVengeancex28
Cookie Monster is offline   Reply With Quote
Old 08-29-2013, 04:32 PM   #3
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
I have no problem roasting the tires in 1st.. and I have a Goodyear Supercar G2's, are you in 1st or 2nd gear?
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 08-29-2013, 04:34 PM   #4
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
You know it's not 426hp to the wheels, right?
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 08-29-2013, 04:38 PM   #5
Camaro2ss2013
Pirelli tires and 1st gear.
Yes I know but it should be at the crank. At the rear most are getting 380-400 on the 2013's with NPP. I will know more as to what its putting to the ground next Friday.
Old 08-29-2013, 04:42 PM   #6
Predator2U
Predator2U's Avatar
Drives: 2011 SGM 2SS/RS M6
From my experience (which is only 65K miles worth), the Pirelli tires are of such a soft compound, you will rarely be able to “roast” your tires at will without doing a higher RPM clutch dump. Once I changed to a harder compound rubber, I can now break traction from a roll.
Mods - Hurst ST Shifter, Cold Air Inductions CAI, Noweeds, Flowmaster's HushPower Axle-Back, Tinted Windows, Gill Fade Decals, Green Interior & Trunk LED Lighting, Pers-Lic-Plates: SKTL GRN
Predator2U is offline   Reply With Quote
Old 08-29-2013, 05:17 PM   #7
SCHMIZE
Drives: 2011 2SS/RS M6
try going into a turn at about that pace n hit the gas in 1st mid turn.. there is no way you won't be able to get those tires going
Volant CAI, Long Tube Headers, Off Road Pipes, GMPP Axle-Back Exhaust, Cutouts
SCHMIZE is offline   Reply With Quote
Old 08-29-2013, 06:11 PM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Are you holding the traction control button down for seven seconds?
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 08-29-2013, 06:14 PM   #9
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Lots of torque management in the stock tune. Not surprising.
Iam Broke is offline   Reply With Quote
Old 08-29-2013, 06:39 PM   #10
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
What my fellow Bee brother says. I found that odd as well. I no longer have that issue.
Bye bye, Bumblebee!
Old 08-29-2013, 07:02 PM   #11
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
Driving down the road at 30 mph ,push the clutch in rev to 5,000 rpms and let the clutch out and hold on!!
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 08-29-2013, 07:02 PM   #12
Denis
Denis's Avatar
Drives: 2010 SS
I spun mine today from a roll for a second...just enough to leave some light marks...with the traction control on
Old 08-29-2013, 07:05 PM   #13
Camaro2ss2013
That is exactly what I figured. My 97 Trans Am WS6 will light the tires up at a 10MPH roll and its completely stock but it will not keep up with the Camaro. I'm very interested to see what the Camaro puts down next Friday.
Old 08-29-2013, 07:15 PM   #14
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
Your tires are actually pretty damn sticky, especially if its hot out. Tune out the torque management system and you will be driving a different beast. I knew the torque management was a REAL issue with the A6 like mine but was not aware it was in the M6, guess so....
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
