Flowmaster Exhaust
Old 09-01-2013, 12:01 PM   #1
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
front wheel spacers/alignment HELP
I installed pfadt coilovers and they were hitting on the tires.. so I installed a set of HR 20MM SPACERS AND they don't seem to be right?? the lug nuts (gorilla locks don't seems to be going on enough.. (maybe they are just didn't seem right)...
But my biggest problem is the front in shaking I can feel it in the steering wheel big time... I am wondering if I need to realign now that I added the spacer and that is what is causing the shake??
thanks for the Help
Whipped416 is offline   Reply With Quote
Old 09-01-2013, 12:18 PM   #2
Supercharged SS
Drives: 2010 Camaro
thanks for the Help
Having a bad alignment won't cause the front end to shake like that. Check the wheel weights first and then make sure the wheels are on flush and same goes for those spacers and locks.
Old 09-01-2013, 03:42 PM   #3
Whipped416
Whipped416's Avatar
going to re check everything.. Im gonna move the smaller 15mm spacers to the front and 20mm to the rear and re check everything... HR told me they would work with no problems.. just don't seem to be right..
HR part number is 4075670
Old 09-02-2013, 12:47 PM   #4
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
I didn't have that problem with my Pedders coilovers even after I installed my 1LE tire & wheel package that are 2 inches wider than stock.
rockrau is offline   Reply With Quote
Old 09-02-2013, 01:11 PM   #5
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
20 mm spacers is pretty darn thick. I would be worried about enough lug thread engagement. Pfadt makes extended length studs. Or there was a thread a while back about using Silverado studs, I think BMR used those. Or even some of the CTS-V studs were used. Never tried it myself though.
1977and2010 is offline   Reply With Quote
