SDTW Custom Wheels & Tires
Old 09-01-2013, 06:32 PM   #29
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I hear ya, the numbers haven't seemed to be a problem, getting the numbers to match at the track is what I keep hearing the issue is. I hope ya get it to track well then I won't be so hesitant to do a 416.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 09-01-2013, 06:33 PM   #30
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Originally Posted by Supercharged SS View Post
He's just leaving extra room for the nitrous!!
. How's your rebuild coming?
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 09-01-2013, 06:34 PM   #31
Turbo99
Turbo99's Avatar
What boost and pulley size are you running? I see OD rears
Old 09-01-2013, 06:35 PM   #32
Supercharged SS
Drives: 2010 Camaro
I made 680 through the auto at 16 psi, blower only on the 376. It was good for a 9.98 at 138 mph. Any more boost it would make more peak power but it was slower at the track because of belt slip.
Old 09-01-2013, 06:37 PM   #33
lexlueger
lexlueger's Avatar
I should have it up and running by the end of this month, just in time for the cooler weather.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 09-01-2013, 06:37 PM   #34
Turbo99
Turbo99's Avatar
And I would think you could use the same pulley set up on a 416 and make about 13psi and 700-715 rwhp.
Old 09-01-2013, 06:38 PM   #35
Supercharged SS
Drives: 2010 Camaro
And you would run 10.50's at the track. Good luck with that. At least you'll save money bc you'll only need a 6 pt bar!!
Old 09-01-2013, 06:40 PM   #36
lexlueger
lexlueger's Avatar
15 psi on R I P 2.8
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 09-01-2013, 06:42 PM   #37
Turbo99
Turbo99's Avatar
I have a 6pt bar and don't want to have to get 8pt, until I decide I don't want to drive the car a lot any more. So a 10.0-10.7 is what I want until I decide to stop driving the car and start trailering it. In cooler weather I should be 10.8-10.9 now. I ran 11.1 last week and it was 85* out and still have room to better the 60'.
Old 09-01-2013, 06:44 PM   #38
Supercharged SS
Drives: 2010 Camaro
Fair enough.
Old 09-01-2013, 06:45 PM   #39
Turbo99
Turbo99's Avatar
Originally Posted by lexlueger View Post
15 psi on R I P 2.8
So the bottom graph on page 1 is about right, it says 16-17psi for a 2.8 OD rear and I am sure you have a decent cam so that would drop it down to 15psi. You should be fine then, I would have thought you would have made alittle more than 700 but it is just a number it only matters what you do at the track.
Old 09-01-2013, 06:51 PM   #40
lexlueger
lexlueger's Avatar
Boost is a measure of restriction. I run mast black label heads. They have decent flow numbers,Lol. I think I have another 30 or so HP laying around on this setup with a proper tune. Track numbers tell the ultimate tale.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 09-01-2013, 06:59 PM   #41
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
I don't know how relevant it is, but I will throw it out there, because I am bored.
I have not been able to find efficiency charts like that for the eforce, but it is a 2300 TVS rotor assembly so it cant be far off in numbers.
My LS402 makes 724 hp @ 12 lbs. Compression is 9.9 to 1. There is more in it but the tune is not super aggressive.
Hope that helps.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 09-01-2013, 07:00 PM   #42
Supercharged SS
Drives: 2010 Camaro
Hope that helps.
Yeah but you can't offer track numbers because your car weighs 700# less.
