Jason 98 TA
Old 09-01-2013, 07:03 PM   #43
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Originally Posted by Supercharged SS View Post
Yeah but you can't offer track numbers because your car weighs 700# less.
I agree. My track numbers are not relevant, but there was discussion about compression ratio and engine size. I am not a true track junkie, but will have some numbers in a few weeks as we rented the track for some tuning and to get some real numbers.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 09-01-2013, 07:08 PM   #44
Supercharged SS
Drives: 2010 Camaro
Those seem like nice numbers for only 12 psi.
Old 09-01-2013, 07:13 PM   #45
realcanuk
realcanuk's Avatar
They are what they are. I guess all dyno's are a bit different and everyone throws hp numbers around, but they really don't mean much except for judging improvements to a specific car. As was said, its the numbers at the track that really count.
The weight diffence by GM specs is only 550 lbs, and I don't know if those weights are for base cars or fully optioned ones. Still a huge difference though.
Old 09-01-2013, 07:21 PM   #46
Supercharged SS
Drives: 2010 Camaro
I'd take a 550lbs weight loss. If I could pick up another .5 I'd really be flying.
I'm curious to get the C7 on the scale.
Old 09-01-2013, 07:23 PM   #47
realcanuk
realcanuk's Avatar
GM lists it as 3300, which is about 100 more than a C6.
Old 09-01-2013, 07:24 PM   #48
Supercharged SS
Drives: 2010 Camaro
Add a little YSI and it should easily be a 10 second car.
Old 09-01-2013, 08:22 PM   #49
H-E
Drives: 2010 zr1 Camaro 2011 vert
I like my 454 2300 combo,its killer on the street and will give you the number your looking for.You have to build a package for your cubes being carefull to chose the right cr...We have a 402 that makes 835hp at 5200rpm then the tb shut so it will be really close to 900 rwhp when we work the bugs out.This is the car we ran 10.20s about 5-6 years ago and it had a 427......It doesn't really matter to me where its the most efficient,ive never turned a Maggie faster and lost power unless we had belt slip. We usually turn our max builds around 22,000....I have a combo that I think will get me over the 900rwhp mark and it is about stock cubes. I will use a 4.125 bore like a 427 so I can use big ls7 type heads and use a 3.5 inch stroke crank,that way I will have a great piston to pin package....I feel this would get the most power you can get out of the 2300....By the way my 454 2300 makes over 800rwhp on 93 through a 9 inch,you can do it with big cubes or small cubes you just need to understand what to do for your particular build. Good luck if I can help you out give me a call.
H-E is offline   Reply With Quote
Old 09-01-2013, 08:44 PM   #50
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
Thanks Thomas, have you tracked your car with the 454? Its gonna be awhile before I do anything just gathering info. I want an enclosed trailer first and I have about 10K left on our wedding/honeymoon left to pay on. Should have all that done by next summer, and the wife just graduated from school and has her RN degree and started work so I should have some of my money freeing up soon.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 09-01-2013, 08:49 PM   #51
H-E
Just a pass or two,of coarse with the 22s lol....Tell her I said WAY TO GO!!!!..We need to get together and let you drive my car ,im sure you will like the cubes lol..
Old 09-01-2013, 09:00 PM   #52
Turbo99
Turbo99's Avatar
Yeah I need to try and get to an event, but they are always in my busy season. I'll tell her!
You need to slap some slicks or at least some DRs on that thing and see what its got. If we get to some where you can run slicks or my DRs lol not that you don't already have access to some.
Old 09-01-2013, 09:10 PM   #53
H-E
If you call running on 22's to 12 second passes then yes, he has tracked his car. I've never understood why he doesn't just strap some track wheels on and show us just how fast the highest HP Maggie will go.
Since you started,actually I run 11.30s on my 22s,its a street car so I keep the same tires I run on the street. You do realize if you had a sixspeed in your car it would be a mid to high 10 second car right? Well assuming you could drive
Old 09-01-2013, 09:19 PM   #54
Turbo99
Turbo99's Avatar
I didn't build it for the track,with my rear brakes the smallest tire I can run is a 20 lol. Ive never been passed by a baby motor and a Maggie on the street
I hear ya, I'm not ready to make my car a drag/street car either..... yet. In a few years prolly. You must have had a decent MPH for an 11.30 on 22's
Old 09-01-2013, 09:26 PM   #55
H-E
It runs good for what I built it for,i do have a goal to run 10s on the 22s,i think I can do it.Its easy to get a number with an auto but with a sixspeed you got to have some skills lol...Are you going to Holley fest?
Old 09-01-2013, 09:44 PM   #56
Turbo99
Turbo99's Avatar
No fest for me I have to fly out for work that weekend, if it would have been this weekend I could have gone.
