BORLA
Old 07-09-2009, 05:16 PM   #1
Stylish
Stylish
Drives: None, Camaro very soon!
Unhappy Continuesly Knocking..
I heared some continuesly knocking only when the car is cold after a while from starting my car. I believe it came from the back side.
I hear it everytime after starting the car in morning. Let's say after 5 mins from starting the car.
After that I don't hear it. Its only in the morning when that car is cold.
Could it be the battery problem? But I am sure that the pulled my car and has been delayed to get it because of the recall thing.
So I don't know really.
2SS.
Black on Black.
RS Package.
Sun roof.
6 speed Auto with tap shift.
Stylish is offline   Reply With Quote
Old 07-09-2009, 10:14 PM   #2
The 305
The 305's Avatar
Drives: 2010 SS/RS Cyber w/Black Strps
Stylish,
Mine does the same damn thing. As you explained it exactly.
Not sure what to make of it...
Anyone?
2010 SS/RS CGM "2SSICK"
[SIGPIC][/SIGPIC]
The 305 is offline   Reply With Quote
Old 07-10-2009, 01:41 AM   #3
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
It's piston slap
http://www.camaro5.com/forums/showpo...25&postcount=2
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP Graduate, A.S. Automotive Technology, CISCO Certified Network Engineer, Telecommunications Specialist
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 07-10-2009, 10:40 AM   #4
The 305
The 305's Avatar
Okay so now what? If I take it in are they going to tell me to hall @ss? Honestly it doesn't sound like it's coming from the engine though...
I will pay more attention next time.
Thanks for the info.
[SIGPIC][/SIGPIC]
Old 07-10-2009, 11:06 AM   #5
Stylish
Stylish
You are right, It doesn't sound it's coming from the engine.
It seems it from the back side of the car. I have a doubt with a battery because it is in the back trunk.
The confusion that I know my car have been pulled back to the plant to fix the recall thing and I believe they did the batter case. What else could it be?
2SS.
Black on Black.
RS Package.
Sun roof.
Old 07-10-2009, 11:17 AM   #6
txaggie_08
txaggie_08's Avatar
Drives: 2003 F-150
Is piston slap a common problem in GM cars? I've only owned one other Chevy in my life, and it didn't have the problem. Is this a serious issue with the cars that GM will not fix or what?
txaggie_08 is offline   Reply With Quote
Old 07-10-2009, 11:39 AM   #7
oachalon
Drives: 2010 Camaro 1SS
gms newer engines dont have piston slap problems anymore. i would say 05 and up seem to be fixed of those problems.
Piston slap doesnt cause any harm if you do have it.
oachalon is offline   Reply With Quote
Old 07-10-2009, 11:43 AM   #8
txaggie_08
txaggie_08's Avatar
Drives: 2003 F-150
Thanks for the input oachalon!!
Old 07-10-2009, 01:45 PM   #9
shiftz33
shiftz33's Avatar
Drives: SS Sedan, SSR, T-Bird, Highlander
My former 2005 Chevy SSR with the 6.0L LS2 engine had a bad case of piston slap. It was considered "normal" and GM would not fix it since they did not consider it a problem.
15 Chevy SS | 04 Chevy SSR | 04 Ford Thunderbird PCR #428 | 06 Toyota Highlander Hybrid
shiftz33 is offline   Reply With Quote
Old 07-10-2009, 02:09 PM   #10
Robert@G-Force
Drives: 04 Cobra
Kind of common
http://pistonslap.com/
Robert@G-Force is offline   Reply With Quote
Old 07-10-2009, 03:44 PM   #11
Stylish
Stylish
If it is really a piston slap and common thing. Then all Camaros should have the same thing. Everyone agree?
2SS.
Black on Black.
RS Package.
Sun roof.
Old 07-10-2009, 04:07 PM   #12
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
when the LS1 first debuted, excessive piston slap was an everyday occurance for most owners. partly because the pistons werent matched to the cyl bores in each engine. its not a serious issue. it is annoying, but as long as you arent running 6000rpm all day long right off the start, you wont have to worry about it.
piston slap still occurs. nearly every motor out there has some piston slap. what you need to look out for is excessive piston slap
as far as it not causing harm? thats
99.9999999999999999% of owners that do have piston slap will never have a problem (save for the annoying noise), but piston slap can be a big problem.
however, it usually takes a long time for any significant damage to occur.
piston slap happens in nearly every motor out there. however, some motors will have more than others.
I piss excellence
and fart awesomeness
Old 07-10-2009, 04:22 PM   #13
baileyrx
baileyrx's Avatar
Drives: 2003 g35
it might be the exhaust pipes heating up & expanding a bit...
baileyrx is offline   Reply With Quote
Old 07-11-2009, 04:16 PM   #14
camaro5's Avatar
Have someone start the car while you listen underneath for location of the noise.
STANDARD DISCLAIMER
