JDP Motorsports
Old 09-02-2013, 01:00 PM   #1
dixonk
dixonk's Avatar
Drives: 2011 Audi Q7
Send a message via Skype™ to dixonk
NPP Exhaust Retrofit
I have a fix on a complete NPP system including the lines, complete muffler system, and diffuser. Is there a way to put it in the car and have full factory functionality without having to use aftermarket controllers? I know it will fit I am referring to the functionality of the system I want the car to be like stock.
dixonk is offline   Reply With Quote
Old 09-02-2013, 01:03 PM   #2
Anaconda
Anaconda's Avatar
Drives: 2013 Camaro 1SS 6-speed VR
http://www.camaro5.com/forums/showthread.php?t=314023
This thread may help.
2013 Victory Red 1SS 6-speed w/ black stripes ordered 8/15/12
Delivered 10/2/2012!
Corsa ZL1 catback exhaust, Black CAI intake with scoop and washer bottle relocation
Anaconda is offline   Reply With Quote
Old 09-02-2013, 03:43 PM   #3
dixonk
dixonk's Avatar
Originally Posted by Anaconda View Post
I read that and I read several others but couldn't find a "factory" solution. I want it to function using stock vacuum lines and fuse box without the need for aftermarket controllers or wiring.
Old 09-03-2013, 01:16 PM   #4
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Probably need to figure out where the vacuum line gets it's main connection and then reprogram the ECM or BCM depending which one actually controls the NPP.
From the NPP in a box instructions, there's an unused vacuum port on the back of the LS3 intake manifold.
Old 09-03-2013, 02:49 PM   #5
dixonk
dixonk's Avatar
Thanks. What I needed to know.
Old 09-03-2013, 03:07 PM   #6
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
You can just leave them open. Many are pulling the fuse anyway to get the same effect.
If you just want On/Off see this thread for an alternate solution
Southern Comfort is offline   Reply With Quote
